    Default megane 3 edc17cp19 missing component
    Hi,i have megane 3,ECU is edc17cp19
    does somebody know what resistor goes here?
    Sep 2013
    garage
    hmm ...only way is to remove rezistor and measure it ...but you can try to remove a rezistor just next to your mising one measure it and put a similar one in the place of your mising one
  3. The Following User Says Thank You to Mr BLACK For This Useful Post:
    DomnulNegru (15th September, 2016)
    Sep 2013
    garage
    i think is a pull up rezistor
    Act Tuning's Avatar
    Sep 2016
    Around
    Watch out, dont messuare other resistor and put the same, thoos type look the same but have diffrent ohms , you need to check from other ecu and fit,
    CVN FIX Vag/Bmw
    Tuning Petrol and Diesel
    High Power Maps
    Custom Tuning Stage 3+ Hybrid
    Dsg Tuning
    I put 1k work
    Sep 2013
    garage
    is working with 1k ?
  8. The Following User Says Thank You to Mr BLACK For This Useful Post:
