And which DTCs you have after?
I was not looking. I was not thinking. Now is the stock map in the car. I'll try this weekend and report. Tnx Bobolin40 for replay.
Br
Too rich mixture. Turbo maps totally wrong, IQ wrong, torque limiter wrong. In my opinion the problem is the RAIL PRESSURE. 50 bar is a bit too much for this one. Try it with 20 bar first, and never touch it again if it is ok. And the EGR maps are fulled with 12 000...leave it stock, and just blank it with a plate and delete the DTC it is better for this ECU, because 12000 does not mean the EGR is closed 100%.
BR.
jozoku1 (28th September, 2016), twchnodictator (21st December, 2016)
The file looks right, there is no problem with the parametrs. What error do you have ?
EGR is also ok, i have this solution for EGR off with no problems or limp. How are your swirl flaps ?
attempt to manually change a little switch behind the accelerator pedal
Make new map. After some attempts car work good. TNX
Br
phl0at
BR.juicewashere
how can 2 replies be so different about this map file ?
