Results 1 to 13 of 13
Hybrid View
    Jul 2016
    Default help pls to program smart key mazda cx-7 all key lost
    hello friends
    pls i need help to can program smart key for Mazda cx-7 usually i am programing smart card with skp-900 without problems but this time even i dont have programed mechanical key so when it try to program the mechanical key no success and smart card can be programed but immo light still flash
    thanks in advance
    scotland clydebank
    how many keys did you program is not a minimum of 2 keys that need programmed and are you using the right key.
    Jul 2016
    yes for sure i am trying to key 4d63
    DK Veteran Automat's Avatar
    Chuichu village, AZ
    Correct, only when clearing I believe 2 needed. Wouldn't light remain solid if one correct key is used, awaiting the second? If light is flashing, test key with cloner or key reader, possibly no transponder detected, missing from key, or bad.
    Jul 2016
    i tried many keys and get the antenna ring out and try and the car dont have problem they just loss the ley for sure
    Jul 2016
    any help pls ???
    Aug 2010
    hi
    try different device....
    Mar 2014
    ivory coast
    Yhi Cyril,you don't need to clear any of the key,you add key when programming
    Sent from my iPad using Tapatalk
    Mar 2014
    ivory coast
    Did your tool ask for out code or incode code
    Jul 2016
    no skp dont ask for code it have auto match and now no leys in the memory cuz the car was starting with smart remote and no chip in the key it was spoiled
    Mar 2014
    ivory coast
    Did you try to add key when you try to programme
    Mar 2014
    ivory coast
    Use a lower programmer like ck100
  13. #13
    Mar 2014
    ivory coast
    It happens to me recently ,I tried M8 ,it programme the car but can't start
    But when I tried Ck100 the car started well,it seems the auto incode in SKP And M8 can't work fine on some Mazda CX-7 ,you have to input the incode manually.
