Autotecno2006 (17th September, 2016)
Originally Posted by Autotecno2006
Hi All, can someone please do Dpf & Fuel Additive off on ford focus 1037391374C40283C.
Thanks P
Hi mate
If ecu is edc16c34 then in the flash dump find string 01 01 00 0C 3B 0D then alter it to 00 01 00 0C 3B 0D.
Write new file to ecu (correcting cks at same time) and that's the switch off solution.
Can not fin this line in this File, Anybody done this type ?
Thanks P
Autotecno2006 (17th September, 2016), bmw325 (12th February, 2018)
Thanks nizarben, tryed your file no faults,but on dash says Engine System Fault. Only Fault was P1922 Fuel Additive Circuit, before and after Dpf was removed.
Any advice ?
remove the fuel aditive ecu .it is under the back seat on the rigt side
Tzepy you are spot on thank you, Also thanks to nizarben looly and icezero2010 for your inputs
regards P
