Results 1 to 4 of 4
    Top Poster bekamon's Avatar
    Mar 2009
    Default Detroit series 60 help
    I have a Detroit diesel series 60 engine. It's make explosi?ns And smoke on the exaust, we disconect the air temperature sensor and the smoke And explosi?ns finish, The injector are good, all data are good, some can help me
    Sep 2010
    I forget what the solution is to this but I have done several. does it more when cold?
    Junior Member rasteiro's Avatar
    Hi mate
    check the fuses is you got one bloan you have that issue o check the TRS em SRS you can have an error ther too
    Sep 2010
    If it is the same problem as I have seen it is the one of the tables having to do with the intake air temperature sensor
