Simply unplug the vacuum hose from the EGR actuator and isolate it...
Cheers!
Cheers!
pike (22nd September, 2016)
not work
fault code 19586 egr system
p3130-35 -10
Here EGR OFF,it is easy in this ecu.
MIL on
Caniho pass please
Can't you disable this fault code by yourself?
If you have troubles with getting the password, post here and i will disable the DTC...
Extremely bad tuning btw...
Regards!
Pass in your PM.
I did not know that your file is modified, I created another file egr off with the base of your file, that file modification is very bad.
Same pass to the other file.
