Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
  1. #16
    Anyone found solution fo this classic radios?
  2. #17
    Jan 2014
    Praag,Czech Republic
    Hi, I have the same radio. I replaced the battery and tried to load different dumps, but I don't have the right one. The radio still has only - - - -.
    Can anyone help?
    Thank you.
  3. #18
    Jan 2021
    Has anyone found a good bin file for the Becker 754 radio. In need of a working file.
  4. #19
    Jan 2014
    HI, try this : https://www.dropbox.com/s/3e6noelqll...01002.bin?dl=0
    Please let me know if it helped.
    Josef
  5. #20
    Jun 2021
    Hi, anyone successfully unlock this radio with eeprom ie. 24c02 ?
  6. #21
    Anyone found solution, that passes for getting original firmware in the ram of the radio, or decoder tool reverse engineering?
  7. #22
    Jun 2019
    hello everyone,
    i'd like to know how to unload the dumb file ? and all day i've been truing but i can't get it, but iy just throws me out every time i try
  8. #23
    BG
    Anyone found a solution or working dump from RAM PCF8571? I will try to write it to 24C01.
    May by this :
    https://www.youtube.com/watch?v=J0fxASPGSw8Regards!
    is the best solution for now..
    From here : https://www.dropbox.com/s/3e6noelqll...01002.bin?dl=0 arhive have got errors.
  9. #24
    Dec 2016
    Quote Originally Posted by treran21 View Post
    PCF8571P is EPROM and not EPROM!
    She must be energized all the time.
    For this, there is a battery inside the radio.
    When the battery is discharged, the dump in the PCF8571P is erased by itself.
    Need a dump from the working radio
    Read without disconnecting the battery .
    In the non-working radio, replace the battery.
    To contacts 4 and 8 PCF8571P be solder battery 3.3V.
    To the 4, 5 and 6 buses, connect the GND, SDA. and SCL from programmer
    Programing PCF8571P read with the working radio dump.
    Do not solder the battery to disconnect the programmer wires from the PCF8571P.
    Also, without soldering the batteries, the PCF8571P should be soldered in the radio and only then it can be repaired
    I am sorry ( google translator )
    Hi.
    Which Part should be used in programmer? 24c01?
    THX
