need security access to do it ????
Brolk..
Brolk..
Press "THANKS" button.
If you press factory setting you might have to activate all functions witch needs security access.
To do factory setting try 19249 security access.but you will have problem i thing to activate all back.
That skoda fabia i done i had no problem but vw golf maybe more secure.
But my golf has more issue internal fault and check sum error.
Sent from my SM-G935F using Tapatalk
Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
Thank you very much.
A consultation, you will know the security access number to activate all functions in #16 VCDS for NSK 5Z1 909 144 F module?
I test with very numbers and nothing. Thanks for your time. Best regards.
Brolk says: "VW eps controler 5Z1 909 144 D eeprom 95320."
Where is it that eeprom? I don?t see in the box even looking two sides of the electronic circuitry.
Hi friends, I relive this post .. I have a VW suran with module 5Z1 909 144 D- fault p1609. After crashing crash. I can not get security key to access channel * 16.
Attached memory reading 95320 of the module.
The memory is on the other side of the board and is micro memory. I attach a photo
Thank you very much and greetings from Argentina
pelu50 (24th May, 2017)
Con que leiste la memoria? que adaptador? la tuviste que desoldar?
Please i need help to remove p160900 on suran brazil 5z1909144d 95320 eeprom is attached
http://www.digital-kaos.co.uk/forums...steering-crash
Thank You
5Z1909144dD read by UPA
drewdom (29th October, 2019), ecumanager (10th June, 2021), Jonatanfunes91 (26th November, 2022), keycar (30th November, 2018), Kinred (7th May, 2018), lumetan (6th November, 2021), magnacin (24th January, 2019), MentadoPlus (5th May, 2019), mestebanf (22nd March, 2019), milerk (25th October, 2018), xseva (2nd November, 2023)
Hola, alguien tiene idea como borrar el fallo?, es una vw suran.... Gracias.
Hello mate, could someone solve this with the file? I read a 95320 is a suran with a blocked address. I appreciate any possible help
:wink
autoelite (10th August, 2023)
