Results 1 to 15 of 25
    Brolk's Avatar
    May 2016
    ARGENTINA Bs.As
    Default vw SURAN steering assistance fault P160900 fault
    HELLO
    VW SURAN brasil 2016, car crash, airbag deployed and steering stop work, i repaired airbag, na fault in, but steering have the code P160900, CRASH SHUT-OFF WAS TRIGGERED, any know how i can solve this fault? is possible reset memory?
    is this fault resetable?
    thanks in advance..
    Press "THANKS" button.
    Yesterday,had here one Polo 1.2 tdi 2010 and was only erase dtc with VCDS,now work ok
    On airbag made the same,no need to repair
    Brolk's Avatar
    May 2016
    ARGENTINA Bs.As
    I can not erase this DTC..P1609 00
    module 44 stering..
    Brolk..
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    try and update vcds and try
  5. The Following User Says Thank You to smirnoff_rules For This Useful Post:
    Brolk (24th September, 2016)
    Brolk's Avatar
    May 2016
    ARGENTINA Bs.As
    Quote Originally Posted by smirnoff_rules View Post
    I did but hat no luck..
    Brolk..
    Brolk's Avatar
    May 2016
    ARGENTINA Bs.As
    need dump clear
    module 44 stering
    VW eps controler 5Z1 909 144 D eeprom 95320.
  8. The Following User Says Thank You to Brolk For This Useful Post:
    eldani33 (28th November, 2016)
  9. #7
    Dec 2012
    EU
    Vcds ori has option---- reset to factory setting.---
    Go to adaptation and look there
    Sent from my SM-G935F using Tapatalk
    Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
  10. The Following User Says Thank You to gttuning For This Useful Post:
    Brolk (27th September, 2016)
  11. #8
    Brolk's Avatar
    May 2016
    ARGENTINA Bs.As
    need security access to do it
    tks
    Brolk..
  12. #9
    Dec 2012
    EU
    Quote Originally Posted by Brolk View Post
    tks
    Brolk..
    i dont think ,,if you need it will pop up in VCDS ,but i dont think look for one it was quick job.
  13. #10
    Dec 2012
    EU
    Had a golf today its in basic setting-->>reset to factory setting
  14. The Following User Says Thank You to gttuning For This Useful Post:
    lush29 (28th September, 2016)
  15. #11
    Dec 2012
    EU
    Make sure do full scan before you do anything.
  16. The Following User Says Thank You to gttuning For This Useful Post:
    Brolk (29th September, 2016)
  17. #12
    Dec 2012
    EU
    On that golf is not that handy.
    I need security access to activate all functions again like steering angle and other stuff.
  18. The Following User Says Thank You to gttuning For This Useful Post:
  19. #13
    Brolk's Avatar
    May 2016
    ARGENTINA Bs.As
    Quote Originally Posted by gttuning View Post
    full scan in the car
    Brolk..
  20. #14
    Brolk's Avatar
    May 2016
    ARGENTINA Bs.As
    upload screenshots..
  21. #15
    Dec 2012
    EU
    On golf7 i think dealer job need security access pin and i dont know yet.this car has more problems in that module 44.so i would need probably flash it with good file .
  22. The Following User Says Thank You to gttuning For This Useful Post:
