Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
  1. #16
    Brolk's Avatar
    May 2016
    ARGENTINA Bs.As
    need security access to do it ????
    Brolk..
    Press "THANKS" button.
  2. #17
    Dec 2012
    EU
    Quote Originally Posted by Brolk View Post
    Brolk..
    If you press factory setting you might have to activate all functions witch needs security access.
    To do factory setting try 19249 security access.but you will have problem i thing to activate all back.
    That skoda fabia i done i had no problem but vw golf maybe more secure.
    But my golf has more issue internal fault and check sum error.
    Sent from my SM-G935F using Tapatalk
    Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
  3. The Following 2 Users Say Thank You to gttuning For This Useful Post:
    Brolk (30th September, 2016), eldani33 (28th November, 2016)
  4. #18
    Jun 2016
    my garage
    Thank you very much.
    A consultation, you will know the security access number to activate all functions in #16 VCDS for NSK 5Z1 909 144 F module?
    I test with very numbers and nothing. Thanks for your time. Best regards.
  5. #19
    Jun 2016
    my garage
    Brolk says: "VW eps controler 5Z1 909 144 D eeprom 95320."
    Where is it that eeprom? I don?t see in the box even looking two sides of the electronic circuitry.
  6. #20
    Sep 2009
    Cordoba, Argentina
    Hi friends, I relive this post .. I have a VW suran with module 5Z1 909 144 D- fault p1609. After crashing crash. I can not get security key to access channel * 16.
    Attached memory reading 95320 of the module.
    The memory is on the other side of the board and is micro memory. I attach a photo
    Thank you very much and greetings from Argentina
  7. The Following User Says Thank You to gev For This Useful Post:
    pelu50 (24th May, 2017)
  8. #21
    Apr 2017
    CABA Argentina
    Con que leiste la memoria? que adaptador? la tuviste que desoldar?
  9. #22
    Top Poster Kinred's Avatar
    Oct 2015
    In the Jungle
    Please i need help to remove p160900 on suran brazil 5z1909144d 95320 eeprom is attached
    http://www.digital-kaos.co.uk/forums...steering-crash
    Thank You
  10. #23
    autoelite's Avatar
    5Z1909144dD read by UPA
  11. The Following 12 Users Say Thank You to autoelite For This Useful Post:
    drewdom (29th October, 2019), ecumanager (10th June, 2021), Jonatanfunes91 (26th November, 2022), keycar (30th November, 2018), Kinred (7th May, 2018), lumetan (6th November, 2021), magnacin (24th January, 2019), MentadoPlus (5th May, 2019), mestebanf (22nd March, 2019), milerk (25th October, 2018), xseva (2nd November, 2023)
  12. #24
    Jun 2010
    Argentina CABA
    Hola, alguien tiene idea como borrar el fallo?, es una vw suran.... Gracias.
  13. #25
    Jonatanfunes91's Avatar
    Jun 2020
    Argentina
    Hello mate, could someone solve this with the file? I read a 95320 is a suran with a blocked address. I appreciate any possible help
    :wink
  14. The Following User Says Thank You to Jonatanfunes91 For This Useful Post:
    autoelite (10th August, 2023)
