Results 1 to 3 of 3
    Default GOLF 2.0L .. charge pressure (N75) measures... ??? help
    Hello
    I share you my messures groupe (11) charge pressures n75 of my golf 2007, what I see is bizzare rates starting from 75% to 4, 5% !!!!!!!! is this normal ?? What is the problem? thank you
    NB; 3500 rev / min I have a limp mod
    Aug 2010
    check your turbo aktuator, does it working freeley all the way? seems your turbo need to be cleaned...
    Jan 2014
    Ro
    overbost..
    • Check Hoses/Pipes to/between Components
    • Check Solenoid Valve for Boost Pressure Control (N75)
    • Check / Clean / Replace Charge Pressure Control
      • Check / Clean mechanism for variable nozzles
