Results 1 to 10 of 10
    DK Veteran cange's Avatar
    Lithuania
    Default zafira b edc16c9 need dtc off
    so need disable p1125 and p0638
    throttle valve actuator is faulty and plug disconnected
    thanks,
    BDM 0281012549_A50359_Z19DTL_ori.rar
    Act Tuning's Avatar
    Sep 2016
    Around
    Dtc removed,
    CVN FIX Vag/Bmw
    Tuning Petrol and Diesel
    High Power Maps
    Custom Tuning Stage 3+ Hybrid
    Dsg Tuning
  3. The Following User Says Thank You to Act Tuning For This Useful Post:
    cange (28th September, 2016)
    Lithuania
    thanks m8 but this solution not work on opels i still getting intermittent flouts wen i scan with tech2
    Member filetuning's Avatar
    Oct 2015
    Dtc Off Work solution P1125 P0638
    No checksum
    BDM 0281012549_A50359_Z19DTL_Dtc_p1125_p0638.rar
    Lithuania
    its the same solution as above, if sensors diskonekted still getting intermittent flouts
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    is the warning light coming on too then ?
    Lithuania
    no check light on with this solution, just dtc on tech2
    stanislav georgiev's Avatar
    Oct 2014
    България
    Let's try this solution
  10. The Following User Says Thank You to stanislav georgiev For This Useful Post:
    pike (28th September, 2016)
  11. #9
    Act Tuning's Avatar
    Sep 2016
    Around
    If you want to disconnect the acuator you need other solution, not ask dtc remove, if you not solve tell me, i send you solution with disconnected actuator.
    CVN FIX Vag/Bmw
    High Power Maps
    Dsg Tuning
  12. #10
    Oct 2014
    България
    Whether you solve the problem
