I have this solution in flash but I don't know if it is enough.
Hello
I have the ecu with these immo files off in eprom and also in flash but the car still won't start. I don't know where the problem is
Test and report
Hi can someone help please, I need an Immo Off for the attached EDC17CP14 from a Skoda Octavia. Eeprom and 2mb flash attached.
Here immo off............
Irmscher (20th November, 2020)
Thanks i'll give this a try today and let you know if it works. By the way this is an ecu i'm trying to clone to help a friend who has a water damaged ecu. Those files are from the original, but do you also need the donor ecu files?
if so they are also attached.
Hi, quick note to say thank you to Brend. The solution worked but the Immobilser Active sign is displayed in the instrument cluster - presumably because only the MPC file was modified?
Hi all,can someone help with Immo Off on this file? is full backup with Kess.Thanx in advance.
Bosch EDC17CP14 0281015029
marionyk (29th July, 2021)
I don t have Ktag just Kess
This is what i have saved by Kess and MPPS.Thank you for your quick answer
Car just start engine for 2 sec and stop
hi all. can somboby help me? passat B6 edc17cp14 need immo off
03L 907 309
0 281 015 029
how much will it cost?
