1037387004 dtc off__crc ok.rar
this dtc say destroy lambda, destroy lambda = destroy dpf which is this car, pass pm
dominik.m (29th September, 2016)
Thanks for help.
Dtc it does not turn on , but engine has not power above 3000rpm.
Some idea.
regards
yes
first. You programing ecu with obd and procedures it's not fine
two. this lambda when you dtc with her, car is emergency mode, with opel cdti you have the same situation
Ecu was programmed by BDM.
Is possible to switch off emergency mode?
sorry for my english.
If you want to try these --> Attachment 400790
In all same ecu all problem can fix in flash! without remod eeprom.
Just need know what you to do.
Best regards.
Some time ago I remove DPF from this ECU and
I have made MOD. Everything there was ok. After several weeks has broken down
sonda lambda. I have mentioned on new . But problem is repeated .
It appears DTC P2A00 . Car is emergency mode. After remove DTC in Ecu,
First bin is orginal. Second is dpf off- mod.
Somebody have idea?
when you write ori file car still emergency mode? what dtc have you for this file?
When you understand DTC OFF can not OFF limp mode!! He can just to not show in diagnostic DTC but car know about DTC and stay in LIMP MODE.
Babos is right.
Test this, if you want, the checksum must be calculated by the tool...
bobolin4o thank You. I will tes and report.
regards
