nobody can`t do it ?
Hi friends, ist here someone who can remove dtc 55F from this ecu? Ecu is EDC16 C39 motor iveco 3.0l like a daily.... This dtc cant be erase with diagnostic. This Dtc can be erased after 10000 motohours when dtc ist intermitent... ecu data ist similar like iveco, or fiat.
file contains flash and e2p
Many thanks!
edit: eobd code ist 0404
Here is the file, if you have limp mode, this will not solve the problem.
Regards!
Pyromaniak (1st October, 2016)
Limp mode no, only a dtc. In our country must car every two years to control of emisions and they read a obd. I try it and report. Thank you.
error stil remains DTC ist intermittent and have code DTC 55F or eobd 0404
i have missed the second code block...
pike (1st October, 2016), Pyromaniak (1st October, 2016)
I try it and report, many thanks for your time guys
Thanks to all you try it, but stil have same dtc
this file its have two dtc table but only one P0404 in file !
i have disable all dtc related to egr but your multicar will go in limp mode very soon !
Full WinOLS user
Custom ENG/GER OLS file for Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
P0404 or 055F are at the same location (227) and only for one location in each maps
Full WinOLS user
pike (1st October, 2016), Pyromaniak (1st October, 2016), stanislav georgiev (1st October, 2016)
Yes, that's right... but he tells, the DTC is still there... ~~~~!
BTW, Babos was made change at 226 position, may be Van Der Lube was not tested your and my second file...
Greetings from Bulgaria!
Babos (1st October, 2016), Pyromaniak (1st October, 2016)
I not worry about that becaus i have big expierence with that. and can to say need good diagnostic for real dtc!!!! i see lot time you off dtc correct but dtc still be active!
And it is not mean you miss!! but some dtc cant to delete via that way.
bobolin4o (3rd October, 2016), Pyromaniak (1st October, 2016)
