Results 1 to 11 of 11
    Default Audi A6 2.7 TDI DPF off
    Please help remove the DPF in EDC16CP34 A6 2.7 TDI 2008y.
    Thank you in advance
    Attachment 400936
    drewdom's Avatar
    Aug 2010
    58?59'13.1"N 6?11'19.4"E
    Here enjoy:
    Please dear members push the button if my work was helpfull!
    And reputation button(star)
  3. The Following 2 Users Say Thank You to drewdom For This Useful Post:
    bobolin4o (1st October, 2016), Dariusz (1st October, 2016)
    May 2015
    USSR
  5. The Following 2 Users Say Thank You to svvag2000 For This Useful Post:
    Dariusz (1st October, 2016), Extremo (7th March, 2017)
  6. #4
    It does not work check blinks and an error 049921 U0301-002
    Software compatible with the motor controller
    Serbia
    WinOLS (Audi A6 (Lukic dpf.zip...try this and report....
  8. #6
    Nothing has changed fault code U0301
  9. #7
    drewdom's Avatar
    Aug 2010
    Man unplug temperature sensors.I told You that whaile I send You Pass.
  10. The Following User Says Thank You to drewdom For This Useful Post:
  11. #8
    MOHCIN2's Avatar
    Feb 2013
    IN GOD'S EARTH
    what dtc that you have before and after mod file what dtc to see what happen you have to disconnect all sensor has related to the dpf there is i think 3 sensors to disconnect it
  12. #9
    The temperature sensor in front of the DPF was badly disconnected.
    Thanks drewdom
  13. #10
    drewdom's Avatar
    Aug 2010
    Quote Originally Posted by Dariusz View Post
    Thanks drewdom
    So now is only one more button to push
  14. The Following User Says Thank You to drewdom For This Useful Post:
    Dariusz (3rd October, 2016)
  15. #11
    chipdanix's Avatar
    Apr 2016
    Poland - Warsaw
    Disconnect
    - differential pressure sensor dpf
    - flue gas temperature sensor
    - catalyst exhaust gas temperature sensor
    http://www.digital-kaos.co.uk/forums...n-Thread/page2
    Nobody one knows everything we learn a lifetime
    repair ecu , dtc , dpf , egr ..........
