HI!
Vw Sharan ASZ 2003
EGR OFF Please!
Thank You!
VW sharan 1.9TDI ASZ 130HP 0281011199 69546.zip
HI!
Vw Sharan ASZ 2003
EGR OFF Please!
Thank You!
Here file.But You came here only for grab files?Whatever I'm in a good mood today.
Please dear members push the button if my work was helpfull!
And reputation button(star)
jomberykaso (13th December, 2016)
hi all can help here i have passat siemens ppd 1.5 and cut dtc P3130 / P1269 / P1266 / P0102
hw 03G906018CE
I have a 2007 audi a8 engine 4.2 tdi and i want to make dpf off. Thanks!
What did You read in those ecu's?Because this is not a good reading.
alex77vl (12th December, 2016)
Please explain me! Two ecu`s?
what tool u use to read ecus?
this engine has two ecu 4.2 WITCH ONE YOU HAVE THE DPF ISSUE IN ENGINE 1 MASTER ECU OR ENGINE 2 SLAVE ECU AND USE FGETECH IS THE BEST ONE FOR THAT OBD JOB YOU HAVE TO RESULT 2M OF EATCH ECU FILE SIZE
drewdom (13th December, 2016)
Hi Saulius,
Please, I need DPF off, EGR off and increase horse power from 110 to 135, if you can. Here is my ECU file: http://www.digital-kaos.co.uk/forums...e-modification
Many thanks,
Motish
Please I need EGR Off on Vw Passat 2.0 TDI 140 hp PPD 1.2
http://www.digital-kaos.co.uk/forums...144_5WP45610AE
Can you do EGR off for this file?
http://www.digital-kaos.co.uk/forums...-8-Turbo-150hp
That would be great! Thanks![]()
Hm, nobody helped with speedlimit... ok... may be somebody can turn EGR off? And if you can explain how you made it(why you changed this bytes) in pm
7H12-12K532-EDE___converted_stock.bin.zip
Hi, can you help me. I need - lambda and DTC off in file - moto BMW F800. Thanks. Josef.
