hello friend. try this solution. pass by pm
Orig_Intern_BerndPatch_EGR_OFF.rar
If i helped, press THANKS and Reputation
Passat3c (20th May, 2019)
TVA OFF POR FAVOR FIAT DUCATO
hello friend you can try this solution. pass by pm. no checksum corrected
peppo egr off.rar
frenk1 (20th May, 2019)
Help me please dpf off honda crv 2010 2.2 diesel
ciao
edc16c32 class a in recovery per dtc 2089
con dtc off ugualmente recovery !!
puoi aiutarmi
egr e dpf già fatto da molto tempo
grazie
here friend you can try this solution. reset dpf by diagnostic before writting. no checksum corrected. pass by pm
crv dpf off.rar
vaneeok (21st May, 2019)
hi friend. please remove egr from dump. many thanks. keep well
I need EGR, DPF and DTCS OFF BOSCH EDC16 +
Hyundai Tucson 2.0 2004 please
excellent contribution master
Hi, please help me - i need delete EGR. Now EGR is broken, ECU have two faults (P1412 and P0490) and car is in limp mode.
Ford C-Max 1.6tdci EDC16C3-9.18
Hello everyone;
im working 2007 Ford F150, just did a Cam Phasher Lockout,
Cam Phaser Lockouts will completely lock the cam timing in the fully advanced position and will eliminate movement and noise associated with failing cam phasers. Cam phaser knock is a common problem in the 5.4 3V Ford Trucks especially in higher mileage or fleet applications. The billet blocks are installed into the stock cam phasers creating a fixed timing gear with no internal moving parts. Fully advanced cam timing will aid in low end torque, just what the 5.4 trucks really need.
Looking to Tune the PCM.. someone please help..
