Merhaba, bana nasıl yardımcı olabilirsiniz? Astra h 2004 z16xep 1.6 twinport delco mt35e EGR can you closed plsss ... p1405 kodu
kess dosyası
kess dosyası
Can you please check are these files ok to flash?
My car (2008 Audi a5 3.0TDI [CAPA]) has been remapped (before I bought it) but has not be EGR / DPF deleted.
I would really like the EGR and DPF delete file for this map (as the EGR valve is showing signs of failing [intermittent EGR error codes read through VCDS]. Any chance of help?
wpark (11th August, 2019)
Hello. I would need DPF off of this unit.
Best regard
Hello...help me please egr off Espace 4 3.0 dci Denso
i need dtc off VALEO V42 renault sandero P420 and P130
Perfect, thank you. I put the map on my car last night and the engine management light due to egr is now off.
Thanks again.
Next job is to remove core from dpf!
Hi everyone!
If someone can help, I would be really appreciated!
I need DPF and EGR off on a 2008 Zafira 1.9 CDTI 150 BHP, ECU EDC16C39
I tried using "a software", the EGR fault went away, the DPF was no faults, but the guy wants to remove it...
The strange is, when I went for a test, the engine overrun... smoking really bad, and had to stall it by engaging gear and release clutch...
Started again, smoke cleared and a slightly knocking also went away...
Not sure if there was already a problem with the car, or if is something with the MOD file...
Attached is both files...
Any help would be really appreciated!
Hit Thanks if helped you!
Thank You for the help!
"A Wise Man can see more from the bottom of a well than a Fool can see from the top of a mountain."
http://www.youtube.com/c/LMAutoRepairs
Hi, i need a Lambda off / Decat file for an already Stage 2 tuned G55AMG 2008 equipped with BoschME 2.8.1
Swiftec have no solution and with Volta file won't start (chk is correct)
Need help please.
Best regards slang5
i need dpf egr off edc16c3 1.9dci
hello, i need to remove lambda off.... dtc p0135, it's from a peugeot 206 gasoline. nfu engine 1.6
hello, i need dpf off file for my nissan
Hey. Kia sorento edс15с7 immo off.
lmsvvavr (30th August, 2019)
