CLK200 kompressor, 163hp 1.8
need more power please
kess v2 readed
HW: 0004466902
SW: 2711530191
kess v2 readed
HW: 0004466902
SW: 2711530191
Can you please remove egr on this file, thanks
Also please repair cks
can you remap this file , around 35hp
passat avf 1.9tdi 131cp to 165hp
range rover p38 2.5
can u help me with error p1445 Continental SID807 tricore TC1796
peugeot 5008 2011 1.6 hdi dpf+egr off
Hello, can you please remove EGR from this ecu?
Thank you so much.
parther,1.6,60kw,edc16c34,read kess
Hello friends,I am looking to disable the EGR on an edc16c34 of a 1.6 hdi, 0281013872
Need dpf off without tuning.
SIEMENS PPD 1.2
passat b6 2.0tdi bmn 170hp
readed by kess v2
hello can anyone do egr off for thios old file edc15c2 from kia sportage 2,0crdi 2005
thanx
Hello can you make on this file EGR off with DTC off for P0400 thank you.
Try this .
thx+rep for pass
lsalt100 (6th November, 2019)
pass please. thank U
Hi, attached is a tuned file for a Mitsubishi Triton 3.2 DiD
Ecu: Denso SH7058
HW: H13W4D56
SW: 1860A48704
Problem: when the wastegate is adjusted to boost more than 20 PSI car goes into limp with DTC P0234 Overboost.
Can you please remove this DTC and most important limp mode for this DTC?
This file was read with a Kess, if a more complete file is needed please tell me, I can do a bench read.
Many thanks, I will click all the good buttons
