Vagabond90 (11th June, 2020)
Hi im from portugal. opel zafira a 2.0dti Remap and egr off+dtc egr?please. Best regards
Hallo
Please , I need dpf egr and flaps off
Zafira b 150hp z19dth 2005 edc16c9
Help me please with Lambda off ( dtc p0420)
Ford Focus 1.0 ecoboost med17.2
hw cv6a-12b684-bb
sw 10sw038724
Best reards from PL
Please help with turning OFF
I made some changes on my car Alfa Romeo 1.9jtdm 110kw.
I removed DPF. I cover EGR..and replaced suction Intake Manifold from alfa 156 without swirl flaps.
So need things OFF. DPF, EGR, FLAPS
regards
anthony
please could you help disabling 35040E and 6F0013 errors from an Actros with OM471 temic ??
Good, I would like to remove EGR is a Merzedez Ml W164 3.2 CDI
Thank you very much.
Good, I would like to remove EGR is a Merzedez Ml W164 3.2 CDIThank you very much.
Hi ,
Remove the runner flap management from here , 1.8 tsi bzb.
Many thanks
Hi, i have an passat b5.5, engine 2.0 tdi BGW edc16u31, the egr is broken and i need to disable the egr.
Can u delete secondary air injection pump from peugeot 407.
If u can what r the files I have to provide.
Thx
Sent from my SM-G610F using Tapatalk
hi ! i need egr off for passat 2.0 tdi bpw ecu siemens ppd . egr was blanked off. thanks in advance!
Hi, i tried the file but is one problem...
With conector off on the egr i have an error on dash, with the conector on the error dissapear but i have not power...
When i start the car i have 2...3sec power and after i lose the power.
I tried the original dump but i killed the ecu
Do you know how to repair this ecu?
Please
MAPS.rar
EGR DPF delete plese 2013 international 4300 maxxforce DT 9 10
