Umpapa (25th November, 2020)
PLEASE EGR OFF
https://www.digital-kaos.co.uk/forum...ht=EDC16C2+EGR
THANKS
Hi to all DK members. i an new to this DPF, EGR DELETE. my main concern is the mbz sprinters, ml and gl models. what tools or programmers are required? to read the modules, and software to delete them. thank you all again.
Hola, ¿puedes ayudarme
con un archivo Ford? Necesito un dtc apagado p0141.
Dear friends i have problem with egr on corsa C 2003y. Z10XE engine.... Please can you make egr off solution for me... thanks a lot in advance...
P.S. I send orig file in attachment
God Bless You and your familly
Boris
hi can you do an immo off for a dodge nitro 2008 edc16cp31
systemlinux (9th December, 2020)
Hello, please delete p2005 dtc from Audi 3000tfsi simos 8.3.
Ciao, ti preghiamo di dpf off nissan cabstar 2.5 2015 con ecu denso d3
can you, please, remove swirl flaps Volvo D5 2007.
Thank you.
Or point me to the base map.
Hello, i tried to do a manual dpf off solution on this but no luck, got a dtc on car center screen.
e61 525d 197hp 3.0 engine edc16c35
Thanks!
Hi, i need EGR OFF, DPF OFF & DTC OFF for my Volvo s40 1,6D Bosch EDC16C34, 12/2005
crashman74 (21st January, 2021)
Hi mates. Please help me delete dtc p1020 from this car. This tdc makes the car go into limp mode. Its VW crafter 2.5 diesel ecu EDC16CP read by ktag. All files loaded.
Hello, can somebody edit my 1.8T ecu? I'm after decat, so i have problem with check engine from secondary lambda probe. I need 2nd lambda off. 1.8T AMK
THX
Bosch
0261207952
1037363579
Size: 1048576 = 0x100000
Cks = 0xB419F48
I'm using mpps v13.
