Hello, can someone help me with dpf and egr off on edc17c41? i found the 2x1 switch but it is enough or should i do something else? i want to learn
HW: F4YQ5E6AFRB8300
SW: 10132126AA
SW ver.: 7G91-12K532-PH
Spare: 7G91-12A650-UH
HW Ver.: 6G91-12B684-BA
Anybody got a file for this ECU? I blocked EGR, gutted the DPF and now I got limpmode....
MANY THANKS!
hello is it possible to delete the egr from the map of this ecu bosch ecd16c2 mercedes and 220 cdi read with rooster? Thanks in advance
Hi friends. Please, help with DPF off.
Megane 3 1,5 DCI
237101478R
237100037R
Thanks!
hello i need help citroen berlingo 1.6hdi
scr offedc17c60.zip
Hi. Please, help with DPF off
2016 Renault 1.6 dci BiTurbo
Help please.
Hello friend. I have immo off of a twingo 2 1.2 I had cleared Immo by mistake.would like to get the pic if it's possible.
Vin VF1 CNO 40H 4456 3197
Thank you in advance
You file
Nobody one knows everything we learn a lifetime
repair ecu , dtc , dpf , egr ..........
Your file be sure to disconnect the sensorsWinOLS (Audi A8 (dpf egr off) - 384620).rar
Hi friends. Please, help with DTC MAF off.
MAF is disconnected. Check with error 17552
Polo 9N3 1,9 TDI
Thanks!
Hello:
I need to turn off DTC P1320 Fiat Punto EVO Magneti Marelli 8GMF.
I have asked several companies about Chiptuning On-line but they do not support the ECU model.
I am desperate looking for a solution Can somebody help me?
Attached original ECU reading by Ktag
try this and report
albertojose (4th September, 2021)
hello
pass.pm
scr off.
hello
pass.pm
scr off.
hi Gita:
I have burned the file to the ECU with Ktag. DTC P1320 is gone, but there is another new code that cannot be cleared U3FFF.
Attached diagnosis image with autel.
Greetings
