Page 84 of 135 FirstFirst ... 3474798081828384858687888994134 ... LastLast
Results 1,246 to 1,260 of 2020
  1. #1246
    Gita's Avatar
    Aug 2009
    dt.tuning.gita@*****.com
    dpf off
    pass pm
  2. The Following User Says Thank You to Gita For This Useful Post:
    Umpapa (25th November, 2020)
  3. #1247
    Oct 2017
    dd1's Avatar
    Aug 2014
    Hi to all DK members. i an new to this DPF, EGR DELETE. my main concern is the mbz sprinters, ml and gl models. what tools or programmers are required? to read the modules, and software to delete them. thank you all again.
  5. #1249
    Jan 2020
    Paraguay
    Hola, ¿puedes ayudarme
    con un archivo Ford? Necesito un dtc apagado p0141.
  6. #1250
    Jan 2018
    Dear friends i have problem with egr on corsa C 2003y. Z10XE engine.... Please can you make egr off solution for me... thanks a lot in advance...
    P.S. I send orig file in attachment
    God Bless You and your familly
    Boris
  7. #1251
    Dec 2020
    hi can you do an immo off for a dodge nitro 2008 edc16cp31
  8. #1252
    Feb 2010
    Quote Originally Posted by krungla View Post
    Boris
    Try this. need realice checksum
    Thanks.
  9. The Following User Says Thank You to serviclau For This Useful Post:
    systemlinux (9th December, 2020)
  10. #1253
    Sep 2016
    budapest
    Default 3000tfsi dtc del
    Hello, please delete p2005 dtc from Audi 3000tfsi simos 8.3.
  11. #1254
    Sep 2015
    Default nissan cabstar dpf off denso
    Ciao, ti preghiamo di dpf off nissan cabstar 2.5 2015 con ecu denso d3
  12. #1255
    Dec 2014
    Default swirl flaps
    Hello,
    can you, please, remove swirl flaps Volvo D5 2007.
    Thank you.
    Or point me to the base map.
  13. #1256
    danypk's Avatar
    Oct 2017
    Default e61 525d 3.0engine 197hp edc16c35 dpf off egr off
    Hello, i tried to do a manual dpf off solution on this but no luck, got a dtc on car center screen.
    e61 525d 197hp 3.0 engine edc16c35
    Thanks!
  14. #1257
    Dec 2020
    Hi, i need EGR OFF, DPF OFF & DTC OFF for my Volvo s40 1,6D Bosch EDC16C34, 12/2005
  15. #1258
    Yhoni's Avatar
    Jun 2014
    Somewhere in time...
    Quote Originally Posted by crashman74 View Post
    Hello friend, here is your dtc off file.
    Pass pm
    If my post has helped you, do not forget to click on the "THANKS" and "REPUTATION" button !!!
    I do not answer in private questions that can be solved in public.
  16. The Following User Says Thank You to Yhoni For This Useful Post:
    crashman74 (21st January, 2021)
  17. #1259
    Sep 2015
    Default Vw crafter dtc P1020 delete
    Hi mates. Please help me delete dtc p1020 from this car. This tdc makes the car go into limp mode. Its VW crafter 2.5 diesel ecu EDC16CP read by ktag. All files loaded.
  18. #1260
    Dec 2020
    Hello, can somebody edit my 1.8T ecu? I'm after decat, so i have problem with check engine from secondary lambda probe. I need 2nd lambda off. 1.8T AMK
    THX
    Bosch
    0261207952
    1037363579
    Size: 1048576 = 0x100000
    Cks = 0xB419F48
    I'm using mpps v13.
