Any "OFF" file (DPF, EGR, SCR, FLAPS, DTC) for FREE! - Page 105
Page 105 of 106 FirstFirst ... 55595100101102103104105106 LastLast
Results 1,561 to 1,575 of 1583
  1. #1561
    Sep 2018
    48
    Can anyone help to turn off DPF and EGR for this ECU?
    VOLVO V70 BOSCH 0 281 012 765 EDC16C31
    MPC564; flash: M58BW016DB
    Thank You
    Quote Originally Posted by Yhoni View Post
    Hello friend, here is your file.
    Click "THANKS" AND "REPUTATION" button and then i will send your password.
    Greetings.
    Hi. I have a question. Engine don't start. The starter runs, the engine starts for 1 second and switch off. Errors ECU:
    ECM-P200A85 Intake manifold runner performance - Bank 1 BUS Signal
    ECM-P200400 Intake manifold runner control - Stuck Open BANK 1
    ECM-P201500 Intake manifold runner position sensor / switch circuit range/Perf BANK 1
    Is it possible to remake the file differently so that the engine starts without DPF and EGR OFF errors?
    Thank You
  2. #1562
    Yhoni's Avatar
    Jun 2014
    Somewhere in time...
    568
    Quote Originally Posted by kozik333 View Post
    Thank You
    Thank You
    Hello friend, check this two zip attached files and report if any fails or if any runs well, please.
    Thanks.
    If my post has helped you, do not forget to click on the "THANKS" and "REPUTATION" button !!!
    I do not answer in private questions that can be solved in public.
  3. The Following User Says Thank You to Yhoni For This Useful Post:
    kozik333 (11th October, 2021)
  4. #1563
    Sep 2018
    48
    Thanks.
    variant 1: original file: Engine START; error ECM-P200200 Diesel Particulate filter efficiency below threshold (bank1)
    variant 2: DPF and EGR OFF: engine don't START
    variant 3: DPF OFF : Engine START : no errors
    variant 4: EGR OFF: Engine don't START
    Can I combine DPF and EGR switch OFF ? :-)
    Thank You
  5. #1564
    Yhoni's Avatar
    Jun 2014
    568
    Thank You
    Ok, i will check and will try fix it.
  6. #1565
    Yhoni's Avatar
    Jun 2014
    568
    Thank You
    Hello friend, check this file with egr off and dpf off and report, please.
  7. The Following User Says Thank You to Yhoni For This Useful Post:
    kozik333 (13th October, 2021)
  8. #1566
    Sep 2018
    48
    You're GREAT Everything works
    Thank You
  9. #1567
    Sep 2018
    4
    Hello, I have 525d and today I remove DPF and cat with straight pipe. Can someone do and software remove ? Thanks !
    EDC16C35
    BMW HARDWARE ID: 08509034
    BMW SOFTWARE ID: 07788805
    BOSCH HD NM: 0281014436
    BOSCH SW NM: 1037500774
  10. #1568
    Oct 2021
    Hello!
    Please DPF OFF and EGR OFF...
    Opel Combo 2008 1,3 CDTI Z13DTJ
    SW 33324C160
    In archive two files: read from my car with Kess and download from dump base. Please modify two files, if my file is error contains.
  11. #1569
    Yhoni's Avatar
    Jun 2014
    568
    Quote Originally Posted by den1975 View Post
    EDC16C35
    Hello friend, here is your.
    Greetings.
  12. #1570
    Yhoni's Avatar
    Jun 2014
    568
    Quote Originally Posted by VladimirSh80 View Post
    Hello!
    SW 33324C160
    Hello friend, which is the reference of the ECU, please???
  13. #1571
    Oct 2021
    Sorry!
    Information from label ECU:
    55566401HL MJD 602.C1/HW04D/3324C160
    COMBO 1.3 MT DPF 6L0SKII1I 71600.133.06
    Information from Kess
    HW MAG 01246O204D
    SW 3324C160
    SW ver. 0005
    55566401
  14. #1572
    Yhoni's Avatar
    Jun 2014
    568
    Hello!
    SW 33324C160
    Greetings.
  15. The Following User Says Thank You to Yhoni For This Useful Post:
    VladimirSh80 (14th October, 2021)
  16. #1573
    Dec 2019
    6
    hi guys
    i need DPF off for captiva EDC16c39
  17. #1574
    Oct 2021
    4
    HELLO I WANT DTC OFF P0420 IX35 2014
  18. #1575
    Oct 2021
    4
    Default DTC OFF P0420
