Can anyone help to turn off DPF and EGR for this ECU?
VOLVO V70 BOSCH 0 281 012 765 EDC16C31
MPC564; flash: M58BW016DB
Thank You
Hi. I have a question. Engine don't start. The starter runs, the engine starts for 1 second and switch off. Errors ECU:
ECM-P200A85 Intake manifold runner performance - Bank 1 BUS Signal
ECM-P200400 Intake manifold runner control - Stuck Open BANK 1
ECM-P201500 Intake manifold runner position sensor / switch circuit range/Perf BANK 1
Is it possible to remake the file differently so that the engine starts without DPF and EGR OFF errors?
Thank You
kozik333 (11th October, 2021)
variant 1: original file: Engine START; error ECM-P200200 Diesel Particulate filter efficiency below threshold (bank1)
variant 2: DPF and EGR OFF: engine don't START
variant 3: DPF OFF : Engine START : no errors
variant 4: EGR OFF: Engine don't START
Can I combine DPF and EGR switch OFF ? :-)
Thank You
kozik333 (13th October, 2021)
Hello, I have 525d and today I remove DPF and cat with straight pipe. Can someone do and software remove ? Thanks !
EDC16C35
BMW HARDWARE ID: 08509034
BMW SOFTWARE ID: 07788805
BOSCH HD NM: 0281014436
BOSCH SW NM: 1037500774
Hello!
Please DPF OFF and EGR OFF...
Opel Combo 2008 1,3 CDTI Z13DTJ
SW 33324C160
In archive two files: read from my car with Kess and download from dump base. Please modify two files, if my file is error contains.
If my post has helped you, do not forget to click on the "THANKS" and "REPUTATION" button !!!
I do not answer in private questions that can be solved in public.
VladimirSh80 (14th October, 2021)
hi guys
i need DPF off for captiva EDC16c39
HELLO I WANT DTC OFF P0420 IX35 2014
