Page 29 of 78 FirstFirst ... 19242526272829303132333439 ... LastLast
Results 421 to 435 of 1158
  1. #421
    Mar 2017
    2015 Chrysler 200 Prox.
    Pin Read: Worked
    Programming: Failed
    Fail to communicate.
    Connected Smart Box and took care of job.
  2. #422
    Jan 2017
    Quote Originally Posted by ps80l View Post
    Pin Read: Worked
    Programming: Failed
    I've had fail communicate, what i do is start the car then shut off and that gets it working for me
  3. #423
    Mar 2017
    Tried that. Even tried it with the car on with the customers key...Nothing. Connected SB and was done 10 seconds later, no errors
    Jose...what are you going to do when it's all keys lost and you can't start car to bypass error? ;-)
  4. The Following User Says Thank You to ps80l For This Useful Post:
    phuckyall (10th June, 2017)
  5. #424
    Dec 2014
    I just checked and I have the Ford 27.03 version. Just bypass failed to communicate. :shrug
  6. #425
    Dec 2015
    Mayaguez, Puerto Rico
    It's too expensive to fail that many times.
  7. The Following User Says Thank You to jmcsecurity For This Useful Post:
  8. #426
    Mar 2017
    Quote Originally Posted by jmcsecurity View Post
    I agree!! They keep promising all these huge updates BUT can't even fix the common cars that most likely we will get calls for....
  9. The Following User Says Thank You to ps80l For This Useful Post:
  10. #427
    Jan 2017
    You have a point there haha, im mostly adding keys so i really dont have much experience on originating
  11. #428
    Dec 2014
    Anybody have any experiene using this tool on VW/Audi. I was browsing thru it and I see it has a "read security code" option and key and remote programming. I'm going to try using it here in the next few days. Would just like some input if anyone has used it and it works.
  12. #429
    Mar 2017
    Quote Originally Posted by vela727 View Post
    Most chinese "key programmers" don't do precoding...so a lot of them are good enough to do vw/audi up to 2005. Forget about doing beetle 00-01.
    If you really want to do VW/Audi....get a programmer specialized in VAG vehicles with pre-coding capabilities. Plenty of good chinese tools that do this.
  13. #430
    Mar 2017
    2006 Mitsubishi Galant..
    Connect machine and first thing that surprises me...Machine is asking me for PIN to program car. Wow!! All newer programmers and some chinese tools automatically fill this window with pin or bypass it completely...
    I get a pin online, programmer says success. Key doesn't work. I wanted to verify pin I put in was good so I re-start and put a different pin. Machine once again says program success. ??? Seems like I can put any random pin and it "supposedly" works...Car never started.
    I connect Smart Box and it automatically bypasses the pin portion and programs key...Done
  14. #431
    Dec 2015
    No pin read on 2001-2006 Jeep Wrangler - Type 1 cars
  15. #432
    Mar 2017
    01 to 06 Wrangler is Type2. Pin read capable via OBD with very few machines out there. Only one Chinese machine can do it via obd and several american machines can.
    I don't see PS80 ever getting this feature implemented.
  16. #433
    Dec 2015
    I read it with a DMAX.
  17. The Following User Says Thank You to jmcsecurity For This Useful Post:
    phuckyall (11th June, 2017)
  18. #434
    ray-ray's Avatar
    Type 2 (VPW) pin read only on some model 2001-06
    I will add it to the list, along with auto pin for USA Mitsubishi Basic and CAN models.
  19. #435
    Mar 2017
    Quote Originally Posted by ray-ray View Post
    Correct....About 80% of type2 systems I've done didn't have immo enabled. Cut key, start car...done.
