Are those updates only for autopad or for the 80 and 90 tablet also?
If you bought your ps80 or 90 threw AKS then you will be updated to USA version. USA version has a different firmware & Gui.
how can i update usa version in my ez500 i just update immo software and other 16 software update it ok with my ez500 can ssome info for ez500 or tip
ray ray what`s the difference between the ps80 and the ps90 besides the size of the pad and the bluetooth?
and also if i buy a ps90 from xtooltech will it be american verison ? explain plz the issue of america version thanks
We use that platform (firmware) PS80/90 to do are beta testing for the USA version. AKS has sold it first 100 units with positive results. He has a contract with XTooltech to be the USA distributor. At that point Cary had a private label tablet built with new firmware (Auto Pro Pad). I'm waiting for my sample to be delivered. The point >>> Xtooltech is a good company offering good coverage with there tool. They have a new focus in the locksmith side of programming. These company main focus before was diagnostics.
Weasel3 (13th March, 2017)
are the ps80 and 90 from AKS have the same software as the ones from xtooltech?
Chuck, you know where he purchased it from? Ray said the ones that he sells at American lock will pull the pin code, but I'd sure like confirmation.
Xtooltech is doing work for AKS fixing the coverage of the tool. They really do have engineer fixing commands, menu,and so on. That why there tablet will be selling in USA under AKS. These tool is not knock off they are developing more programs.
Ray-Ray can you confirm that it can pull the newer Chrysler can pin codes
Works this tools with european cars? or is only for USA and China?
current list of working systems and things coming soon
just recently completed:
1. Acura/Honda (sync ecu &a immo, Ariel sync) 2016 all lost smart key.
2. Chrysler ( pcm vin rewrite, wynn vin & pin rewrite, 4 & 5 digit pin read via obd2, micropad programming)
3. Ford ( parameter reset, quick reset all lost keys, door pad pin read 05-17 ,2013-16 Fusion bypass)
4. Lexus/Toyota ( eeprom virgin dumps to all models, also ready to start toyota g quick reset no 16 minute wait )
5. Infinity/Nissan( improve pin read 08/09, bypass 20 better guide on programming proxy, remote function added)
6. Gm (remote section added, pin read add new system
Ford PATS4 & PATS5 10-Minute Bypassworking
Ford Parameter Resetworking
Voltage Detection
Chrysler Type1 & Type2 PIN Read (EEPROM)working
Ford/Lincoln/Mercury Keyless Entry Keypad Code Readworking
Nissan BCM to PIN Conversion: Supports the old 5-digit BCM as well as the new 20-digit BCM found in 2013 and later Nissans and Infinitis.working
Ford HEC & PATS2 10-Minute Bypass: Skip right on through the normal 10-minute wait.working
Hyundai & Kia Old & New PIN Code Read: No more buying PINs from the dealerworking
Ford Fusion 2013+ System Rolling Code Bypass (No NASTF Needed)working
Toyota G-Chip Programming w/ No 16-Minute Waitworking
Jeep/Chrysler/Fiat New System PIN Reading & Programmingworking
Complete Chrysler CAN PIN Reading & Programmingworking
Honda 2017 Proximity System Programming working
Audi/VW 2013-2016 Programming coming soon
Dodge/Mercedes Sprinter Bypass & Programming coming soon
Subaru G-Key (80-Bit) Programming coming soon
Subaru 2017 MSOP EEPROM In-Circuit Programming w/ Adapter coming soon
2005 VW Touareg?????
Toyota H-Chip Programming w/ No 16-Minute Wait not sure of status
Ezmony23 (4th March, 2017)
sleepyrz for what tool is this current list for " ?
it for xtool ps80/90
Ray ray where are we at on release of the autopropad
phuckyall (13th March, 2017)
Is there another forum for Usa users or is this the only one you guys know of?
