Page 62 of 78 FirstFirst ... 1252575859606162636465666772 ... LastLast
Results 916 to 930 of 1158
  1. #916
    ray-ray's Avatar
    Yes I could use your help when I get closer. The data has been collected just waiting on the engineer to release a beta version. But with the holiday and Chinese New Year coming soon after. I’ve been trying to release new updates but China is not motivated during the holidays.
  2. The Following User Says Thank You to ray-ray For This Useful Post:
    milehighlockdoc (27th December, 2018)
  3. #917
    keymax's Avatar
    Quote Originally Posted by camelgd View Post
    Caddy Catera seems to be the same kind of orphan car. Already 20 years old, no pin pull, no AKL program on any aftermarket tool that I can afford. Anybody doing these cars?
    Opelinfo.com
  4. #918
    May 2018
    Quote Originally Posted by ray-ray View Post
    Feel free to contact me with anything, wheneve you need for any update/feature.
  5. The Following User Says Thank You to elivai For This Useful Post:
    ray-ray (13th December, 2018)
  6. #919
    Jan 2018
    Just did a 2018 Dodge Journey Friday using the AD cable. Worked perfect. We tried it with brother-in-law's SmartPro first to see how it would go then added a second with my PS80L. For reference on this model the junction block is in the door frame pillar on the left (drivers) side back door. You have to pop a trim piece out and remove a Phillips screw then pull the trim loose. It is a tight fit but you can slip in and plug the harness in without removing the trim panel. We did notice that when we programmed the prox with the SmartPro the door locks cycled when it took. With the PS80L the locks did not cycle but we just kept pressing the unlock button and moved it around the center console. Eventually it timed out and said successful. Checked it and it was good. Interesting that the SmartPro does Pin Bypass while PS80L required me to read the pin first - which it did no problem. Any word on when XTool is planning on releasing a cable?
  7. The Following 4 Users Say Thank You to Loydslock For This Useful Post:
    lock-key (20th December, 2018), milehighlockdoc (19th December, 2018), mkopytekchi89 (20th January, 2019), ray-ray (19th December, 2018)
  8. #920
    ray-ray's Avatar
    First thank for your info. Xtooltech is out for there holiday New Year will be here soon. Then by February a dragon holiday after that they start cracking. I know there are things me and Erik have the work on (new corolla smart system, ford 2018, Honda proxy 2018) I want to start doing more cloud base programing for those Europe cars.
  9. #921
    Dec 2017
    Ford 2018, I hope it comes soon. Thanks for the update, if I can help in any way just PM me. I have plenty of new F-Series trucks I can call that I turned away.
  10. #922
    camelgd's Avatar
    Jan 2011
    South Illinois
    Quote Originally Posted by N54TS View Post
    Shouldn't turn these away. Treat like all keys lost. https://www.youtube.com/watch?v=eYPozkxxlpg
  11. #923
    Dec 2017
    By doing this, can I add in a total of 5 keys, for example?
  12. #924
    ray-ray's Avatar
    Allex in the video is my son learn from the old man.
  13. The Following User Says Thank You to ray-ray For This Useful Post:
    camelgd (22nd December, 2018)
  14. #925
    camelgd's Avatar
    Jan 2011
    South Illinois
    You should rightly be proud. Good head on his shoulders and produces good video.
  15. #926
    camelgd's Avatar
    Jan 2011
    South Illinois
    Follow instructions on pad, you can add more than just the two.
  16. #927
    Dec 2017
    Thank You! APP support said this wasn't the case about 2 weeks ago. Then again, I haven't gotten very far whenever I call them.
  17. #928
    camelgd's Avatar
    Jan 2011
    South Illinois
    Also, when you have two keys you can onboard program more...
  18. #929
    ray-ray's Avatar
    Reset and 2 keys can be added only. The fix is in but the engineer are out in holidays.
  19. #930
    camelgd's Avatar
    Jan 2011
    South Illinois
    I thought I had added keys by on board on two different f150 2018. I will check my records, was at local dealer, I've been wrong before. Well, I found one ticket 2018 added third key, like I say, I've been wrong before.
