Page 73 of 78 FirstFirst ... 23636869707172737475767778 LastLast
Results 1,081 to 1,095 of 1158
  1. #1081
    Mar 2017
    2002 Pt cruiser add remote. FAIL!!!!
    Done with cheap chinese tool in a few seconds
  2. #1082
    Jan 2017
    USA ����
    CURRENT FEATURES
    BMW CAS 1, 2 & 3 key programming
    Chrysler / Jeep / Fiat new system PIN reading & programming
    Chrysler CAN PIN reading & programming
    Chrysler Type1 & Type2 PIN read via EEPROM
    Ford 128-Bit add-a-key & all-keys-lost programming
    Ford Fusion 2013+ system rolling code bypass (no NASTF needed)
    Ford 10-Minute bypass on all-keys-lost for all Ford systems: Bypass the normal 10-minute wait.
    Ford parameter reset
    Ford/Lincoln/Mercury keyless entry keypad code read
    GM PIN code reading
    GM Remote Programming
    Honda 2017 proximity system programming
    Honda transponder programming: Super-quick!
    Hyundai & Kia old PIN codes: converts VIN to PIN for 2007 and older
    Hyundai & Kia new PIN code read: No more buying PINs from the dealer (smart keys)
    Nissan BCM to PIN conversion: Supports the 5-digit and 20-digit BCMs
    Subaru G-Key (80-Bit) add-a-key & all-keys-lost programming
    Toyota H-Chip programming w/ no 16-minute wait
    Toyota G-Chip programming w/ no 16-minute wait
    Toyota/Lexus proximity system 6 & 7 programming all-keys-lost & add-a-key (ie. 2017 Toyota CH-R & Prius Prime)
    VW/Audi 2013-2016 programming for add-a-key
    VW Touareg 2005
    Chrysler Pacifica 2016+
    Volvo key programming (2008-2015 select models/non-prox)
    Maserati key programming (2015-2017 Quattro Forte & Ghibli)
    AutoProPAD New Features Releasing Soon:
    Audi/VW 2013-2016 programming for all-keys-lost (coming Q1 2019)
    Chrysler Type2 PIN read via OBD2 (coming Q4 2018)
    Hyundai & Kia new PIN code read: (slot keys) (coming Q1 2019)
    Fiat 500/Dodge Promaster/Promaster City key programming (coming Q4 2018)
    Full PIN read for all 2017-2018 GMC vehicles (coming Q4 2018)
    Transponder motorcycle programming (coming 2019)
    EEPROM key value reading/editing from BIN dump (coming Q4 2018)
    Remote unlocking w/adapter (coming 2019)
    BMW FEM module key programming via EEPROM (coming 2019)
    BMW CAS3+ (coming 2019)
    Subaru 2017 MSOP EEPROM in-circuitprogramming w/ adapter (coming 2019)
    Alfa Romeo programming
    Chrysler Pacifica 2018+
    Maserati programming
    currently end of Q2 2019
    how we doing on these ?
  3. #1083
    Oct 2017
    Quote Originally Posted by ps80l View Post
    If you read my post, I'm talking about a remote key. NOT smart key
    The menu is wrong for the key section and this is how it's suppose to look...
    One button 11-13 and other button 14-
    Now looks...which is wrong
    -2014 and other button 2014-2019
    Gotcha
    Sent from my SM-N950U using Tapatalk
  4. #1084
    Mar 2017
    2004 Jeep G. Cherokee remote programming fail.
    Done with cheap chinese tool...
  5. #1085
    Oct 2017
    what's up with BMW? can anyone use ANY functions for BMW in the APP? I called AKS and they said it's a known issue that BMW don't work. those are deceptive sale tactics right there. you can't advertise a product does BMW and it doesn't even connect to BMWs anyone else experiencing the same ?
  6. #1086
    ray-ray's Avatar
    Cas 1,2,3 with internet connection is working. The issue lies in the hardware on the kwp protocol others are working.
  7. #1087
    Oct 2017
    the other options like to scan for codes on different modules isn't working for BMW I'm assuming that's the root of the issue as well
  8. #1088
    Feb 2014
    I'm currently looking specifically for a device which can support Subaru and Volvo. I see XTOOL now offers many devices - some with IMMO functions, some without. But it seems like all devices have the same IMMO functions and says it supports both car makers. Am I correct?
    Second question is a bit more tricky - which one has the better support for the mentioned cars - XTOOL or Lonsdor. Can anybody compare?
  9. #1089
    ray-ray's Avatar
    Xtool has no Volvo and Subaru is very little, but support is there.
  10. The Following User Says Thank You to ray-ray For This Useful Post:
    autoTkey (12th July, 2019)
  11. #1090
    Oct 2017
    I can't complain about support with the APP however I'm pretty bummed out about the BMW. I'm hoping they find a solution soon
  12. #1091
    Oct 2017
    2006 Galant programmed remote but didn't program transponder even though it says successful and it even asks you if you want to add another one. neither option works
  13. #1092
    Dec 2017
    Quote Originally Posted by esx503 View Post
    Mitsubishi are usually very picky about only using OEM keys. Are you using that or aftermarket?
  14. #1093
    When the subscription expires can we still do key programming requiring an internet connection?
  15. #1094
    Oct 2017
    Quote Originally Posted by N54TS View Post
    maybe that's it since I'm using an aftermarket
  16. #1095
    Dec 2017
    I've had the same issue. I only use OEM on Mitsubishi now.
