Automat (31st March, 2017), mehmet becker (31st August, 2017)
The firmware will be change and your eeprom and tag tool with other goodies will be sent to you as soon I fill there ready to be ship. I'm also working on a calculator that will find key in dump and display it for you. At that point you could write the Keylogic to a chip to start the car or add your value to the calculator to add back to the dump.
whats wrong with them now? the eeprom and tag tool that is
I wanted to add Pomona clips and the goklip with the pogo pins for in circuit reading. I also going the add a Ariel tester and the new style power packs. I want to make sure you have all the tool it take to get the job done.
Ray. I tried everything to remove all the chinese cars from the Immo menu and did not succeed. How do I do it?
Erik has your number he can teamview your tablet and remove those files.
Erik tweaked the layout of my machine. Now it's starting to look like the machine AKS has promised. Thanks
Drove 40 minutes to go to my very first car with PS80. 2013 Kia Forte Prox... It failed!! What a waste of time...
phuckyall (30th March, 2017)
http://autoproapp.com/AutoProPAD-App...-Guide-1.0.htm
How did it fail?
Did you have hazards on?
Did you start with ignition off?
I have programmed several hyundai/kia prox. The hazard light is not really required. Supposedly it wakes up the computer but I have never done it when using tcode. I did try the hazard light and steping on the gas pedal/open close doors. This also did not work. Get a fail to communicate after I put code.
Text Erick and he told me they are aware their is a problem with this system. So I asked why not remove it from the menu.... Answer... Because we might forget about working on it. So I suggest everyone contact tech support and verify a specific system will work before taking on job and driving there.
Then XTOOL PAD 2 is for American market
2nd car I try and it fails. 2012 Focus. Programmed fine with Smart Box.
phuckyall (31st March, 2017)
With "US Ford" should have clear that problem, I'll check on it.
Yes. USA FORD
PS80 made the dash flicker and then the dash went very dim while it searched for password. Found it and then got an error.
With SB the dash stay fully lit throughout the whole procedure.
phuckyall (2nd April, 2017)
Went to try PS80 on a 2012 toyota all keys lost.
Pressed all keys lost and boom! Car was reset. Wow! Never used a machine that has done a reset that quick. Thumbs up!
