hello
i have a ford c max DIESEL 2008
BATTERY LOST POWER I CHANGE NEW ONE CAR NO START
I USE THE BOTH KEY SAME NO START
HOW CAN I DO FORD RESOLVED THE PROBLEM
hello
so do you have a immo issue ...?
immo is in dashboard
you need to synchronize pcm (ecu motor) with the instrument panel, often this problem
HOW CAN I MAKE SYNCRO ECU AND INSTRUMENT PANEL ON FORD C MAX
OR IF SOMEONE HAVE PAIRE FILES CAN HELP ME
Use ford IDS, simplest way
Sent from my SM-G930F using Tapatalk
read the eeprom 95160 from ecu and the mcu from the cluster and post here thw file's
Lucioantonio and Antwnhszr are right.
Scripts for Multi-PROG
Best regards.
Dragon
immo off for the ecu its possible
No immo off ....
Best regards.
Dragon
