for this ecu solution to monitoring TQ off not work, check your modify file
I'm looking for torque limitation/torque monitoring in this ecu. Someone can help me ?
I Think, that it's 22 maps start at 0x1818F8 and last 0x184AD0. And maximum of inner engine torque at 0x18527C
I'm right ?
Peugeot_EDC17C10.zip
Without modify these maps I have problem with ESP system. Engine goes to service mode.
With modify, engine working ok but i have message "Engine fault: Need repair".This message is displayed only once after reflashing ECU. And dtc code is FAFF (in BSI module)
You got this wrong, something not ok with your tune, we did alot of edc17cp10 psa never seen that problem or fault, check you tune file again.
CVN FIX Vag/Bmw
Tuning Petrol and Diesel
High Power Maps
Custom Tuning Stage 3+ Hybrid
Dsg Tuning
Yes this ecu torque monitor off no problem. Same procedure as most edc17 with torque monitoring
Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
Professional Engine Software Development
upload ori and tune file, i see
Original is above.
Mod is attachment.
Mod is very easy. TQ limiters, relative engine torque of function monitoring, smoke, turbo, driver wish and EGR hysteresis. I don't understand where I made a mistake.
308_mod.zip
nbtechnic (13th January, 2017)
for you this is good tune?
sorry but this mod it's not good. 2 limiter nm its not change. You modify maps turbo its crazy, because you change turbo pressure to 180nm?
Hamai (5th October, 2016)
