I would help you, but i dont have manual solution for this, you ask for help, and tell us how to help you , nice.
CVN FIX Vag/Bmw
Tuning Petrol and Diesel
High Power Maps
Custom Tuning Stage 3+ Hybrid
Dsg Tuning
chipdanix (5th October, 2016), kinketotua (6th October, 2016)
Look at this
DPF EGR of edc16c34 .rar
Nobody one knows everything we learn a lifetime
repair ecu , dtc , dpf , egr ..........
dariobmw (6th October, 2016), stanislav georgiev (6th October, 2016)
For compare
Tested solution.
Pass PM
chipdanix (9th October, 2016)
THANKS for help chipdanix and bodzio012 i try and report fo result , but i need to drive some km for sure result
ACT TUNING thanks too if your intention was to help is ever wellcome
maybe you will lucky...same car i have read with fgtech...done manual solution dpf off with help of a good specialist member dpf -egr from DK...reflash ecu...dpf ok...sensor temperature disconected error >NO....sensor differential pressure disconected error NO....module aditiv pump disconected error NO...but the shi+ error p1187 variant selection OK...uhhh...only IDS ford maybe can help me...i wait this tool
BTW...for no risks better to read and write BDM
inside forum:ask me about...i will tell you all that i know
make me working for you...i will give you my paypal account
outside forum:
chiptuning,egr,dpf,add blue,dtc,Eu clones
why is this car difficult to do manual dfp off then ? just wondering
It`s not dificulty such ecu,also exist more than 3 damos for PSA EDC16C34 ! the problem are from tools like Fgtech or Kess when file are writing via OBD,its "lose" power train coding in eep ! similar "story" are with Reno/Nissan/Suzuki ecu,it lose immo configuration !
Full WinOLS user
Custom ENG/GER OLS file for Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
chipdanix (9th October, 2016), pike (8th October, 2016), smirnoff_rules (10th October, 2016), stanislav georgiev (10th October, 2016), teamtuner (9th October, 2016)
being the easiest ecu to remove from car and open l wouldnt even try over obd , so if l get one in and full read will be ok to get a dpf file then
In these days all it want "fast",this one are the reason for such trouble ! noone still remember how have start this job 15 years ago...new age are come !
Full WinOLS user
bobolin4o (10th October, 2016), smirnoff_rules (9th October, 2016)
Swiftec Solution work very well witour any issue,
CVN FIX Vag/Bmw
High Power Maps
Dsg Tuning
outside forum:
chipdanix (9th October, 2016), smirnoff_rules (9th October, 2016), stanislav georgiev (10th October, 2016)
solved problem with great help of mihaiservice and babos friends DK...thanks a lot my friends
outside forum:
swiftec ??? oh yeah, when you have this ecu and car for automatic transmission we''ll talk................. and than you need must write post to forum " help I do 4 solution and I still limp on abs "
