dadal (25th November, 2016)
thanks mate,, this important info for me,,, so,.I do not need to program or to make virgin or to adapt ,,,I can directly 2nd hands power steering mount in car
hmmm then editing of dump is indeed necessary just when there are fault codes .
thanks again mate
FUnny, always when i'm trying to figure out complicated problem here, on DK, i am finding Soxten
soxten (21st February, 2017)
bobbik (22nd February, 2017)
Hi, I from CHILE, i have a megane steering with 1 trabnsistor mosfett BAD, i change. and don't run. You have a 24c16 code for a good steering?.. I download files, don't have pasword for unzip. You can help me? Tanks.
pasword pleass
So, is it the steering column or the lock that needs coding?
[QUOTE = OllieTuning1; 3233881] pasword pleass [/ QUOTE]
Is correct password ? But I try extract any hace comunication"wrong password"
Hi. I have df035 error on my megane 2 EPS. I want to try download fresh dump to the Eeprom. Who solved the same problem such way?
I have a problem with the power steering, I have error c1606 and c1608. Can someone make me a virgin from the original file?
best regards
Give me please origin or repaired 24c16 dump. Thanks.
Hi, my friend. I had problems with the steering wheel of the Megane 2, but the dump does not solve the problem of errors DF002 and DF035 because if the error is active it will again be entered in the eeprom and will block the steering wheel. I was able to reset the error with the Delphy 150 diagnostics, after I soldered the fets and the connector I soldered to get to the eeprom. I assembled the steering wheel and reset the errors and it worked, to our regret after a month the error occurred again, and so more and more often. Since I have another steering wheel I put it on and now everything is fine. I disassembled everything twice.So you need to fix the fault first and then reset the errors with the diagnostic device, and if the fault is fixed, everything should work properly and continue to work.
geocity (18th March, 2021)
