Results 1 to 14 of 14
    Jan 2009
    Default Audi a3 CAN pin code from dash
    I use carprog to read ori pin from dash, but cant read used dash pin because is SAFE (not valid key)
    Any tips?
    Tnx
    Apr 2011
    in lebanon
    Quote Originally Posted by ziko View Post
    Any tips?
    Tnx
    Hello.
    yes its show you safe cause there is no working key,what year is your Audi A3? what kind dash is micronas or NEC or ?,for example see here the manual.http://www.codecard.lt/carprog/softw.../prod_772.html
    Jan 2009
    Its CAN with 93c86, 2005 MY
    smokey08's Avatar
    Essex, UK
    Is that file from the new dash?
    Jan 2009
    Yes, but as I know cant find pin code by dump
    Jan 2016
    Fujitsu dash. SMOK is good at this kind of dash.
    smokey08's Avatar
    Essex, UK
    Are you 100% sure you have chosen the correct year with carprog? Im sure I have used carprog of these with all keys lost and it even shows the full 7 bytes of the CS.
    Jan 2009
    Yes same choosen yeara and read ori dash ok, but not read used dash with no good key
    Jan 2016
    You must read Sec Block with Smok put it in editor and you'll have all data. Last time I did Fujitsu dash swap it didnt read key info (even in ori dash with key) but I put ori sec block to donor dash and everything was ok. Both clusters had errors after somebody tried to swap them maybe thats why it didnt shaw keys.
    audiopoint's Avatar
    Mar 2011
    MACEDONIA
    help pin from dash A3
    audiopoint's Avatar
    Mar 2011
    MACEDONIA
    ... any help
    Apr 2011
    in lebanon
    Quote Originally Posted by audiopoint View Post
    ... any help
    Hello.
    as i know by dump can't get pin code, by obd2.
  13. The Following User Says Thank You to haroutioun For This Useful Post:
    audiopoint (15th October, 2016)
  14. #13
    Jun 2016
    invest in cable, some things they're hatched with colleagues
  15. The Following User Says Thank You to Klimek For This Useful Post:
  16. #14
    Jun 2016
    smok ,psryk
