P1613 PEUGEOT 307
Results 1 to 15 of 21
    Top Poster skona's Avatar
    ON AIR-LANDING
    Default P1613 PEUGEOT 307
    Have trouble P1613 with a 307SW 1.6 HDI 110 hp 9HZ EDC16C34.
    Injector coding was lost after disconnect batery .Injectors now is coding with lexia but trouble p1613 stay.
    after starting engine , have max 3000 rpm . starting next time engine work normal without problems p1613
    tried configuration ECU ABS---ENGINE BLOWER---CRUISE CONTROL--- without success
    br
    Oct 2015
    Try all injector code with 00000010(all 0, and last two place type 10)
    Maybe you have bad configuration ar you most virgin that ecu eeprom...
    Sent from my Nexus 5X using Tapatalk
  3. The Following User Says Thank You to sjsephy91 For This Useful Post:
    skona (12th October, 2016)
    chacarita's Avatar
    Argentina
    post youre vin number maybe i can helpyou
  5. The Following User Says Thank You to chacarita For This Useful Post:
  6. #4
    ON AIR-LANDING
    Traying put code injector 00000010 , code accept but trouble P1613 stay
    vin number VF33H9HZC83959916
    br
    Oct 2015
    Can you shot you configuration screen on pp2000 or diagbox?
  8. #6
    Aug 2011
    Try disconnect battery for 15min.
  9. #7
    ON AIR-LANDING
    battery disconnected 20min --- trouble P1613 -
    injector cod 1- 00000010
    2- 00000010
    3- 00000010
    4- 00000010
  10. #8
    ON AIR-LANDING
    battery disconnected 20min --- P1613
    Engine ECU
    Intermittent fault. Configuration incorecct or not carried out
  11. #9
    Oct 2015
    Abs is multiplexed
    You must change all invalid value...
  12. #10
    ON AIR-LANDING
    Quote Originally Posted by sjsephy91 View Post
    Abs is multiplexed
    configuration Ecu is allow only coding lnjectors -pp2000
    other configuration is disable (alternator class - type off garbox - airconditionig .........)
  13. #11
    Oct 2015
    Try with virgin eeprom... If you need, i will send you..
  14. #12
    Babos's Avatar
    Mar 2012
    i think i can help with that probme.
  15. The Following User Says Thank You to Babos For This Useful Post:
    skona (14th October, 2016)
  16. #13
    ON AIR-LANDING
    Quote Originally Posted by Babos View Post
    to day problem is not solved
    i need help
    br
  17. #14
    ON AIR-LANDING
    please can you send me virgin eeprom
  18. #15
    Is the sw in MPC original?
