there's a problem with torque limiter protection if not chenge this protection TL will have always error and limp mode
43452 - single 8 bit value
4359C - 8x12 map
44c88 - single value
50e4c - 8x14 map
50f5c - 8x14 map
5578e - tq limit map
55812 - tq limit map
57aa4 - tq limit map
57b0c - 8 x13 map
57c40 - 8x16 map
57f5a - single value
57f5c - singe value
580a8 - tq map
580fe - tq map
58206 - tq ?
58230 - tq map
5886a - single value
5866c - single value
79b1a - tq 8x21 map
75b68-7b644 - gears tq limit maps,
Is there something else ? I have problem after tune this file car get limp mode in high speed .. and dtcs 4d7f - DDE ECU
BMW 120D 177 17CP OBD 0281014238 509475.rar
this post will be helpfull for much users..
yes i know... so what can i do with this ? perfectly sync all limiters or what ? there is anymore tq limiters ? or any switch to turn off?
This is stock file, what the problem, where is the tune file ?
CVN FIX Vag/Bmw
Tuning Petrol and Diesel
High Power Maps
Custom Tuning Stage 3+ Hybrid
Dsg Tuning
OBD UDS_mod_boostpop_tqlimitpoP3.rar
its for you for check, this ori file sended is not perfect ori file, car wchich i do come to me with modified file ( im have own dynomet, its got 202 ps 370 nm, actually 212ps 400 nm) but getting limp mode, limiters are set to 430, there must be something what is limiting more power, and getting limp mode.
Tadas chipDPF (14th October, 2016)
Zalejak (14th October, 2016)
it was decreased by previous "tuner" i wasnt touch this
anyway, thanks for your reply
and thanks for ori file
e90_tqproblem_pop3.rar
next limiters touched.. gonna test tommorow.
Someone maybe see anything to correct or find another limiters ?
@edit
Still same problem
Thread up !
Hi mate,
First of all forget about Sigle 8 bit value-is fake,no need to touch this value is not Torque Limiter
Real TL maps for you:
57ABA 10X1
57B3A 8X13
57C74 8X16
580D4 21X1
58132 3X21 TL/car speed
5825C 21X1
5886A 2X1
592CA Single value TL
796F6 8x10 Torque limiter /temp.
797BE 8X10 Torque limiter /temp
79B58 8X21 Torque limiter
7B568,7B58A,7B5AC,7B5CE,7B5F0,7B612,TL by gear 1 to 6
7B634 TL by reverse gear
Only one question mate, if you want to tune this nice car why don't you study a Damos file????Is not an EDC15 , is a modern ECU, can get good results in two hours work in front of laptop and taking info from different forums.
On my mappack I studied more than two hours ,and result was a good , safe and working tuned file.
Real engines don't need forced induction
Who needs a turbo when you have a stupidly quick naturally aspirated engine?
