Results 1 to 8 of 8
    Sep 2015
    Washington, DC
    Default 13 BMW 328i CAS 3++ downgrading problem
    A10CF238-D85C-458C-8D39-19D9A42DDE67.JPGWas adding an extra Comfort key into BMW & during the downgrade it fail to upload the flash, using VVDI2, now it won't do anything, is that anything I can do to fix it before I have to buy a new CAS? Tried a few more times to repair CAS but it goes really slow & @ 80% it gives message Fail to upload Part 1
    Jun 2010
    Why does the CAS3 + ever have to be downgraded by VVDI2? VVDI2 can not even read at the CAS3 + partly EEprom and it comes the message that this type is not supported.
    droidwayne65's Avatar
    Aug 2015
    North America
    Quote Originally Posted by Kinskeys View Post
    Well, you'll now have to do what you should have done before trying to downgrade with VVDI2, of all things: remove the CAS, read flash and eeprom. Post copies so they can be repaired.
    <---- Coin of the Realm.
  4. The Following User Says Thank You to droidwayne65 For This Useful Post:
    narkeleptk (22nd August, 2019)
    Sep 2015
    Washington, DC
    Quote Originally Posted by droidwayne65 View Post
    That’s what I did almost 2 years ago
  6. #5
    narkeleptk's Avatar
    May 2017
    USA
    I always try to manually back up cas modules before doing anything else. They are so easily corrupted.
  7. The Following User Says Thank You to narkeleptk For This Useful Post:
    brend (22nd August, 2019)
  8. #6
    dimitar's Avatar
    Use winkfp and update cas
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  9. #7
    p1et's Avatar
    Oct 2013
    Guys, this is almost 3 year old thread I;m certainly sure he solved this
  10. The Following User Says Thank You to p1et For This Useful Post:
    droidwayne65 (22nd August, 2019)
  11. #8
    Aug 2015
    North America
    Quote Originally Posted by p1et View Post
    LMAO! Now that, "almost two years ago", makes sense!
