Network connection is required only for ID48-96bit and 4d83-80bit. All other are offline.
It's not connected to the transponders you use for writing the cloned data.
Did you try unlocking Honda controls?
I have the connection diagram v3 but the option in the keytool menu is not
[QUOTE = PerryZhang; 3440364] esa parte de la compañía de Xhorse aún no se ha puesto, estamos en proceso de prueba. [/ QUOTE]
ok it's good to know
just wait
Hello all I’m trying to renew a Audi A5 key part no 8T0 959 754 D with vvdi key tool. I have tried PCB1 8T0 959 754 D 868 MHz after finish writing transponder can no longer be detected and led not working. So I tried PCB2 8T0 959 754 D this transponder detected but when you put battery in led light stays solid. Also I have tried universal type 5 this also not detected and no led working.
Has anyone else renewed this style key and had this issue?
Update have support from xhorse well done Samic.
Hello ,
I Tried To Clone Remote Control For Seat Ibiza 2015 The Key Original before clone with vvdi key tool work but after clone not work remote control How To solve the problem to come back the remote control for original key also Key VVdi Key Tool Not clone
Add key. With decent tool.
@ Galee, i renewed 2 genuine Audi bcm2 keys one was 8T0.959.754.D with PCB 233.453.111-02 using same 868 pcb no from the list, and the other 8KO.959.754.H with PCB NO 233.453.211-02 , using 4H0.959.754.DD 868 Pcb No from the list, and both are fine, and verified by tango and KD900 too.
Hi Nazz2 yes today I renewed also one audi key 8T0 959 754 D with Pcb inside No. 233,453.111-02 and successfully programmed to 2009 Audi A5 AKL. The problem was that the key I had was same key part no 8T0 959 754 D but pcb verson did not match I must of missread doh! PCB no 233.453.011-02 it has to match 100%. Strange thing is when renewed read as unlocked remote working and read by vvdi 2. Hope they do a update some time soon.
chcp (9th December, 2018)
Does anyone programmed chrysler M3M renewed key?
Or no need to renew? Because used key is also read Unlocked Crypto as new one.
How can I do for to buy tokens for ID48 96 bits calculation?
I have only VDI Key Tool, recently bought.
Thanks in advanced.
Best Regards.
Hi can I ask where you guys are buying id46 clowning chips for key tool? I’ve been trying to get some for a long time. 3dgroup no stock since April and vvdishop no stock.
