Page 111 of 176 FirstFirst ... 1161101106107108109110111112113114115116121161 ... LastLast
Results 1,651 to 1,665 of 2634
Thread: VVDI KEY TOOL
  1. #1651
    Apr 2016
    uk
    Quote Originally Posted by Galee View Post
    Hi can I ask where you guys are buying id46 clowning chips for key tool? I’ve been trying to get some for a long time. 3dgroup no stock since April and vvdishop no stock.
    Aliexpress?
    Inviato dal mio HTC 10 evo utilizzando Tapatalk
  2. #1652
    Hello Yes have tried order chips for keytool id46 cloning chips from Aliexpress etc. But they send incompatible chips! Don’t work with key tool or vvdi2. Have contacted all supplies no joy.Where is 46 cloning chips available from from guys I’m losing loads of jobs because of this?
  3. #1653
    Feb 2014
    Are you sure it is the chips problem? There are some cars which the KeyTool cracks but can't write to any chip. Maybe you should try writing on an XN remote?
    Also you can order from UOBD2, they have good chips, at least they used to.
  4. The Following User Says Thank You to autoTkey For This Useful Post:
    Galee (14th December, 2018)
  5. #1654
    newone's Avatar
    Oct 2016
    xhorse 4d chips if generate to id 63 80bit can be used to learn from obd to new ford?
  6. #1655
    Quote Originally Posted by autoTkey View Post
    Yes collect all data then asks for id46 clone chip but then error incorrect chip. You got a link please for these chips? via pm no doubt I can’t find them thanks.
  7. #1656
    Feb 2014
    I just checked them - they are there but it seems they are out of stock... Sorry.
    Try to write on an XN remote (xhorse remote with transponder function).
  8. #1657
    Maartinj's Avatar
    Nov 2010
    Everyone who have COPY 48 96bit available on Keytool / VVDI2
    Xhorse give free online calculation till 25.02.2019
  9. The Following 8 Users Say Thank You to Maartinj For This Useful Post:
    amigokola (16th December, 2018), chcp (16th December, 2018), darkoman (16th December, 2018), doctore (16th December, 2018), ghostrider72 (16th December, 2018), milehighlockdoc (16th December, 2018), RIMKACHIP (16th December, 2018), WRX 14 (26th December, 2018)
  10. #1658
    Feb 2014
    Hello guys. Yesterday I tried to clone keyfob from VW Passat B5 year 2005 with my VVDI KEY TOOL and don't work. Procedure I followed:
    1-Special clone
    2-I was pressed each button in order suggested by tool
    3-When three buttons were get I was pressed WRITE
    4-In frequency adjust I had put 434.00MHz and in in BAUD I had put 502, because original keyfob had this parameter
    5-Tool gaves me message Clone succesfull, but keyfob don't work.
    Can somebody help me with that?
    There was a problem with tool or my mistake?
    Thanks in advanced.
    Enviado desde mi E5306 mediante Tapatalk
  11. #1659
    Feb 2014
    Quote Originally Posted by Anass GM View Post
    Hello ,
    I Tried To Clone Remote Control For Seat Ibiza 2015 The Key Original before clone with vvdi key tool work but after clone not work remote control How To solve the problem to come back the remote control for original key also Key VVdi Key Tool Not clone
    Attachment 578133
    Hello friend, I tried to do similar work, in VW Passat, keyfob is identilcally but my problem was that the cloning keyfob don't works, look my comment, and if you can tell me if I can done something bad. In your case I think the problem was you tried to clone keyfob out of reach area of the car, and original keyfob was unprogrammed. You only needs reprogram it. Keyfob cloned work?
    Thanks in advanced. I hope to help you.
  12. #1660
    Jul 2018
    Please How To Solve This Problem When i want register in the application Phone no message received in my email
  13. The Following User Says Thank You to Anass GM For This Useful Post:
    nagib (2nd February, 2019)
  14. #1661
    Nov 2018
    setup the account on a computer with the Update Kit by the binding menu and then log into the application with the information you registered with
  15. #1662
    Jul 2018
    Quote Originally Posted by milehighlockdoc View Post
    Thanks I Solved The Problem
  16. #1663
    Jul 2018
    It is True Now 48 96 BIT Is free
  17. #1664
    Oct 2016
    Scotland
    well free calculation token until 25th Feb, but you'll still need pay for initial authorisation.
    See post by MaartinJ like 6 posts up the page.
  18. #1665
    Jul 2018
    Quote Originally Posted by Maartinj View Post
    It's true for the first calculation obliged to pay ??
  19. The Following User Says Thank You to Anass GM For This Useful Post:
    RIMKACHIP (18th December, 2018)
