Page 120 of 176 FirstFirst ... 2070110115116117118119120121122123124125130170 ... LastLast
Results 1,786 to 1,800 of 2634
Thread: VVDI KEY TOOL
  1. #1786
    Mar 2015
    UA
    Hey. How or in what way does a key chain learn to Hummer Н3 2008?
  2. #1787
    Jun 2016
    Hi Guys, my first post on this site.
    Ok cloned a vauxhal astra mk5 2009, Had to sniff from the barrel and calculate then copied to a chip.
    Worked great, first time.
    Problem im having is getting the remote to sinc/central locking to work. Ive tried everything possible.
    (HKCYSEA 10pcs/lot 3 Button Universal Remote Key DS Style English Language for Xhorse VVDI Key Tool)
  3. #1788
    Apr 2016
    uk
    Quote Originally Posted by GabyGadget19 View Post
    You need to program key precoded for astra h 7941 to have remote working.
    You cannot clone key and program manually or with diagnostic
  4. The Following User Says Thank You to comizelu For This Useful Post:
    GabyGadget19 (16th February, 2019)
  5. #1789
    Jun 2016
    Many thanks Comizelu, If i can pull the pin code out ill prep the chip then program it through obd then the fob should sinc correctly. Will get back if i get it working. Thanks for info.
  6. #1790
    Top Poster rojhat's Avatar
    Sep 2015
    france
    id46 touareg cloning work 2 times after immo active add with tango and kessy eeprom .
    Envoyé de mon SM-A605FN en utilisant Tapatalk
  7. #1791
    Top Poster mexjack's Avatar
    Philippines
    Could you add 315 mhz mqb keyless remote??
    Enviado desde mi SM-G935F mediante Tapatalk
  8. #1792
    Jan 2018
    CA, USA
    ive been interested in getting a programmer to make other keys besides bmw which is what i do now. does this programmer offer a wide range of keys? im in US so can this programmer generate keys for gmc, ford, dodge, honda, nissan etc on OEM style keys? as i always see videos on people generating flip style keys made by xhorse by connecting chip to key tool. i would like to be able to make OEM stle keys as most people would like a key like original. like BMW keys i know it takes quite a few programmers to do most vehicles, but i would like to start with a decent tool with wide coverage as im just recently getting into other makes, so looking for a a decent priced programmer that i can learn with and is i get enough customers invest in more.
  9. #1793
    Jun 2016
    I've just paid £218.56 to activate authorization. On activating this correct me if i'm wrong i should get free 1500 points for doing so? Then i can convert them for tokens. Am i right or wrong.
  10. #1794
    Top Poster ramiz auto lock's Avatar
    Nov 2017
    NORTH LONDON
    That's how it should be.
    Or that's how it was when I done it.
    Sent from my BV9000Pro-F using Tapatalk
  11. #1795
    Jun 2016
    Thanks, Ramiz thats what i thought. Its not showing me any 0 points.
    Ive emailed xhorse support and there aint no support. Not happy.
  12. #1796
    Nov 2017
    NORTH LONDON
    Contact the seller he should be able to help you
  13. The Following User Says Thank You to ramiz auto lock For This Useful Post:
    GabyGadget19 (19th February, 2019)
  14. #1797
    Mar 2017
    Quote Originally Posted by ps80l View Post
    I encountered this today. Machine will only collect one time....after that it would just beep and the screen just showed 1 data collection.
    Have done many 48 clones with no issues. First I deal with this. Car is not the problem as I tried cloing with my KD-X2 and it did 100% same error as Xhorse.
    Got a hold of xhorse tech support. They said some volvo require special data aquisition. You get the first data aquisition and now have to wait 30 minutes to get second, and wait another 30 minutes to get third and so on and so on...So cloning a 48 chip for these "Special Volvos" is over two hours. This they never mention when selling the 48 clone feature....
  15. #1798
    Maartinj's Avatar
    Nov 2010
    price not telling any ...
    we dont know what you bought, and for what device
    so better back to your seller and fix it , or post more info, so we can replay
    but they not tell that this can be done within a 1-2min
    this same way you can blame MB tool that require remove IR key over 150 times ...what total need close to 2 hours .....
    this is procedure , and every step must be done in proper way ....
  16. #1799
    Feb 2014
    So why do you blame Xhorse for that?!
    They offered you a solution, didn't they?
    Problem is with the car - it has too long code refreshing timeout.
  17. The Following User Says Thank You to autoTkey For This Useful Post:
    Maartinj (20th February, 2019)
  18. #1800
    Jun 2016
    vvdi key tool id48-96 bit activation which cost me £218
    and on doing so it stated you get 1500 points free.
    On the device its showing Available bonus points 1550 remain points 0.
    I understand you need to buy points.
