Page 137 of 176 FirstFirst ... 3787127132133134135136137138139140141142147 ... LastLast
Results 2,041 to 2,055 of 2634
Thread: VVDI KEY TOOL
  1. #2041
    sdnatlst's Avatar
    Aug 2011
    England
    Well on the 4D ford proxy system, you need to INSERT proxy key into side of steering coloumn, it only fits original FORD remote, to emergency start. So this case, it wont work anyway
    only on ID49 system was there a place to sit the key, under armrest to emergency start. which would work if you can find space for your TP
    most systems smart have slots, only fitting original remote case. So for me these proxy universal keys are only good for emergency to get customer going initially.
    Tools owned -
  2. The Following User Says Thank You to sdnatlst For This Useful Post:
    ghostrider72 (18th July, 2019)
  3. #2042
    ghostrider72's Avatar
    Jul 2012
    UK
    On ID49 it generates TP automatically and its detectable with tester so not an issue. Only problem will be with 4D as there is no physical space for TP mate.
  4. #2043
    sdnatlst's Avatar
    Aug 2011
    England
    How would you insert this xhorse smart remote into the emergency slot for the start though? Its sized for original remote
    4d doesn't need transponder to start the car it just uses proxy.
    Transponder only for emergency start when battery in key is dead.
    Tools owned -
  5. #2044
    PierreTheron's Avatar
    Centurion,South Africa
    Great and working
  6. #2045
    Quote Originally Posted by sdnatlst View Post
    At least in my case it is working . 2 minute to steal a ford .. how very surprising . I alredy mady 50 off them disapear .. so i made a crapload off money in this time
    Do not charge me for crimnal offencences
    You must take vvdi on for this
    So easy to take a vehicle
  7. #2046
    Just a bar off soft soap to make imprint off key .. cut it and then easy to make transponder afterwards
    the soap ius just yto give imprint ..so you manuallly aqd the cutting code to machine
    Is like depth 1322322
  8. #2047
    scotland clydebank
    thinking of buying vvdi mini key tool can somebody explain if the free token they use everyday for one year can be used for id 48 cloning on line or do you need to buy
    anything else apart from the super chip transponder to make a id 48 clone thank you.
  9. #2048
    Nov 2013
    Just heads up - do not upgrade Key Tool!!
    I confirmed from few sources - they already stopped manufacturing of original Key Tool. I was stupid enough to upgrade to version 3.2.5. Originally tool was NA (North American) firmware, but with 3.2.5 firmware became GLOBAL. Some remotes are missing now (not on the list, and not in the XHORSE app either, so Mini Key tool is useless, I have it too). So if you're happy with what you have - do not upgrade above version 3.2.2 or even lower! There's no option to downgrade back to local (for example, North American) version - confirmed with some sales rep in China. "i am sorry that the GL version can not be back. i confirmed with engineer" - was reply.
    Very disappointed.
    Until now it was best tool to use, new mini key tool just stupid toy with SOME features of Original Key Tool.
  10. The Following User Says Thank You to ranchero For This Useful Post:
    keysmith (24th July, 2019)
  11. #2049
    Nov 2013
    Quote Originally Posted by godfathertre View Post
    Don't need to do anything, 1 token per day comes automatically (even though you can expect to wait more than 24hrs for 1 token to reappear). Tokens do not collect, there never more than 1 token (if you don't buy more). Don't need Super Chip either, cheap id48 blank transponder works just fine. Works for now, don't know how long it will last, doesn't look like XHORSE cares about customers too much (see my post above).
  12. #2050
    Feb 2014
    I doubt anyone is relying much on Xhorse tools for generating remotes. KeyDIY has always had the edge on this function.
    On the good side for Xhorse is they probably will keep supporting and updating their first Key Tool, like they did with the older Condor machines (hopefully).
  13. #2051
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Xhorse released latest remotes database
    which support more than 23 brands and more than 400 models of cars worldwide
    ...pls inform everybody to upgrade KEYTOOL and Mini KEYTOOL asap
    many thanks to friend kevfield
  14. The Following User Says Thank You to daxxer For This Useful Post:
    chcp (24th July, 2019)
  15. #2052
    daxxer's Avatar
    Apr 2014
    in circuit :-)
  16. #2053
    daxxer's Avatar
    Apr 2014
    in circuit :-)
  17. The Following User Says Thank You to daxxer For This Useful Post:
    PierreTheron (29th August, 2019)
  18. #2054
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    ....and latest
  19. #2055
    Feb 2014
    So KeyTool can generate smart/keyless remotes now? OK, cool. But it would've been best if there were empty remotes available to generate those on.
