castin (17th September, 2019)
I said earlier in another thread, that I thought the KtoolMax would be the replacement for the smaller key tool and the planned bigger Pad.
But here it seems that both are scheduled, and on their way.
http://www.vvdishop.com/wholesale/xh...i-key-max.html Price is ready on this one.
http://www.vvdishop.com/wholesale/xh...-plus-pad.html
For these complaining that renew doesn't go well - VVDI manual for renew function is total mess - incomplete, many mistakes, missing connection diagrams, misleading numbers etc. And I'm talking about manual version 2, old version is even worse.
You need to find and download as many renew manuals as you can find (for Handy Baby, KD and other tools). They all have flaws, so you will need to read them and use your brain to figure out which connection diagram and part number is correct and which number on VVDI key tool screen corresponds to that. Then it works well (mostly).
However, just yesterday after unlocking 13 keys I've got one with exact problems as someone above - key is unlocked but no RF transmission (remote doesn't work). File was correct 100%, so I guess it might be fobik's problem, or someone messed with it already earlier.
BTW - can anyone recommend cheap PCF programmer which able to read/write PCF7941, PCF7961? I have many locked Chinese fobiks, no renew file for them, files for original fobik don't work on them (fobik becomes unlocked, but just like someone above said - remote doesn't transmit after unlocking with wrong file). I'm thinking to read file from virgin Chinese fobik, and then write it to others.
Fernandowap (25th September, 2019), VictorVonDoom (27th September, 2019)
Im think its no possible to read chinese key. Its read protected and firs must erase chip, then its open.
I have trouble updating my VVDI Key Tool within 3 weeks !! In the update kit only gives me glitch, I can not use the machine, because it is in version 3.2.5 outdated version.
SN: VK01630050
AR: GL
Can someone help me with this problem?
Solutions in the area of automotive coded keys, all automakers.
Anyone have solution to sniff coil ignition Peugeot 207 208 ??? With handy baby need to click down for this type of ignition but with vvdi key tool not working. Thanks
Envoyé de mon iPhone en utilisant Tapatalk
Good afternoonmy vvdi key is not upgrading to version 3.2.8Serial is VK01525603.This in version 3.2.5
Upa-S ,Vvdi key tool, Zedfull, Xpad, KM100, Obdmap, Scanmatik pro2, Ioterminal, Pcmflash, Mdflasher, Fvdi, Ck100, Fvdi, Roudrill
So today I've got same problem as other people with other keys - after renewing Chrysler KOBDT04A key it shows "unlock OK", when checked - shows "unlocked", but all buttons stop working (no RF).
For renew I connected as renew manual tells, removed little resistor before flashing. Used KOBOT04A file in Key Tool.
6 keys - same result - all show "unlocked", but buttons dead on all of them (all were checked and working before flashing).
Any suggestions?
If VVDI support reads this forum - I would like to hear from them.
My firmware version is 3.2.4 (NA)
