Page 169 of 177 FirstFirst ... 69119159164165166167168169170171172173174 ... LastLast
Results 2,521 to 2,535 of 2641
Thread: VVDI KEY TOOL
  1. #2521
    Hampshire
    Has anyone noticed a screen size and fonts problem today on xhorse app on mobile fone after an update? or is it just me.
  2. #2522
    PierreTheron's Avatar
    Centurion,South Africa
    Few days late but this tool does prove itself in its own way somehow mate (cracked key immo coding onrover 75 and MG tf with pectron . They not cheap but easy to do if you know how ..Same a 75 models with speciail soft on the web ..
    Problem is i only get call once a year now
    So they getting more expensive
  3. #2523
    Oct 2015
    Does anybody know how to write custom eeprom data to an xhorse smart key via vvdi2?
    When i uncheck the load from default database option, i get asked for eeprom.bin and eeprom.hex files.
    Anyone have a clue how i generate these files?
  4. #2524
    Feb 2014
    I think only Xhorse engineers can generate them. These functions are to be used only when support asks you to.
  5. #2525
    Feb 2014
    This is not the right thread for your tool mate. This is only for VVDI Key Tool. Good luck!
  6. #2526
    Feb 2021
    when i clone a chip and then generate a remote, the generate remote function deletes the chip, and if i generate remote first then chip ,it deletes the remote, what am i doing wrong guys? wireless remote
  7. #2527
    digi men's Avatar
    Nov 2013
    EU
    Wireless remote, as i know,when you generate, it generate chip and remote togheter, if you want separate, bether take wired one, corect me if iam wrong ?
    Stop worrying about what can go wrong, and get excited about what can go right.
    PRESS THANKS IF YOU LIKE MY POST AND IT HELPED YOU
  8. #2528
    Feb 2019
    NIGERIA
    Quote Originally Posted by digi men View Post
    You are very correct, to clone you have to use a wired remote
    <<<<<<--------KINDLY HIT THE THANKS BUTTON IF THIS POST HAS BEEN USEFUL TO YOU
  9. #2529
    didi_du_93000's Avatar
    France Paris
    Hello, anyone have Sucess on creat Nissan qashqai remote 2 button?
    Envoyé de mon LYA-L29 en utilisant Tapatalk
  10. #2530
    Feb 2014
    [SOLVED] I have problem generating proximity remote. I put remote with battery inside antenna and when I push generate it says internal error. I will post pictures. I hope somebody can help. Thanks in advanced
    Problem was SOLVED. I had upgraded firmware from 3.3.2 to 3 3.4 and proximity remotes works perfect. Thanks for all.
    Enviado desde mi SM-G930U mediante Tapatalk
  11. The Following User Says Thank You to davidobd2 For This Useful Post:
    KADE007 (17th May, 2021)
  12. #2531
    Feb 2014
    Did you use the phone app to generate?
  13. #2532
    Jan 2021
    please key your device all version to latest,it is better for us to check problem,thanks every one
  14. #2533
    Toyota smart key generation.
    To generate every new key it will cost you 200 points ( which is a lot ) but after that you can generate 1000 times THIS one absolutely for free.
    Is this something only I dont understand??
  15. #2534
    Jan 2021
    yes, it is set as that, every new remote first time generates will cost 200 bouns points, then will never cost bonus points even if you use other paid option to generate. it is regulation。
  16. #2535
    Quote Originally Posted by xhorse Jay View Post
    .....then will never cost bonus points even if you use other paid option to generate. it is regulation。
    Do you think customer going to return the key to me? To your info, the average locksmith will use it once and never see this key again. What the point of the benefit telling people " each key only once charge the points"
    I dont use xhorse remotes so had to pay $60 for points to be able generate a few keys.
