Page 173 of 177 FirstFirst ... 73123163168169170171172173174175176177 LastLast
Results 2,581 to 2,595 of 2641
Thread: VVDI KEY TOOL
  1. #2581
    Maartinj's Avatar
    Nov 2010
    315Mhz exist
    no matter if is kessy or not kessy
  2. The Following User Says Thank You to Maartinj For This Useful Post:
    Weasel3 (8th April, 2022)
  3. #2582
    Aug 2016
    Just one warnning for user vvdikey tool,don't try prepare proxy key via app iphone or android app,keytool programming success and after proxy key is death! (in may case key XSKF01N) not possible again to revive,i try with vvdi2 and vvdikey tool with special option back to live key but not possible, key is death!
  4. #2583
    Jun 2013
    Quote Originally Posted by Maartinj View Post
    315Mhz exist
    The option is Standard 315Mhz MQB blade key with remote .
    If this also works on Keyless.
    Which I might think, is what you claim.
    I am very thankful for this info.
  5. #2584
    Mar 2018
    UK
    Quote Originally Posted by MaxMin View Post
    fake pcb mate
  6. #2585
    Oct 2018
    egypt
    Is there a way to solve that ... only for china
    wbr.
  7. #2586
    Maartinj's Avatar
    Nov 2010
    Quote Originally Posted by hesham10 View Post
    yes, you need talk with your seller , you not mention him what database use your device, or they sent wrong
  8. The Following 2 Users Say Thank You to Maartinj For This Useful Post:
    hesham10 (14th April, 2022), milehighlockdoc (20th April, 2022)
  9. #2587
    auto techniek's Avatar
    Mar 2017
    Any idea if i can generate 3G0 959 752 k remote for Passat B8?
    Which one to select?
  10. #2588
    Maartinj's Avatar
    Nov 2010
    Quote Originally Posted by auto techniek View Post
    simple look into APP and available models
  11. The Following User Says Thank You to Maartinj For This Useful Post:
    auto techniek (30th June, 2022)
  12. #2589
    Fallen's Avatar
    A question about the new xhorse xm38 toyota remotes.
    They list them as being able to produce 8A 0351 9900AAAA 312/314 remotes which are used on Rav4 amongst others.
    There is no listing for this remote when try to generate them.
    There seems to be a lot of the boards missing that they say they can produce.
    Am I missing something here?
  13. #2590
    Mar 2017
    Tried all option on passat. Car start but remote does not work at all.
  14. #2591
    Feb 2014
    It should work, but you must use the App on your phone - there's much more information there than on the KeyTool. Most important bit is the feedback that everyone leaves and gives you exact answer which model and how to program it.
    Or if you want us to help you, you need to give full information for the car and the working key.
  15. The Following User Says Thank You to autoTkey For This Useful Post:
    auto techniek (2nd July, 2022)
  16. #2592
    Mar 2017
    Car is vw Passat 2015
    Verstuurd vanaf mijn CPH1903 met Tapatalk
  17. #2593
    Feb 2014
    If you have tested with all generated keys from the Xhorse list and they don't work then problem is not in the keys or Xhorse.
    What do you use for programming?
  18. #2594
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Maybe someone can help me...
    We have now a working Toyota Aygo 4D 70 key...
    Can we clone transponder now with key tool max and Superchip...?
  19. #2595
    Maartinj's Avatar
    Nov 2010
    Quote Originally Posted by figani View Post
    simple check if chip is clonable or not
