figani (15th July, 2022)
Is it a comon bug on key tool mini? at the time of calculating id48 - today it took like 120 minutes! key tool is switching itself off after some time - this is normal, if you don't use it for some time. When try to re connect manually or auto - app is frozing on bluetooth search, even when key tool showing BT connected. only option is to close the app and open it again.
Did not had time to make video, but next time will do.
Generating Audi 754 smart key doesn't work with KeyTool/MiniKeyTool/VVDI2. The PCB is AD006, v1.0.
I thought this key was (Keyless version).
Or is it two types of keys.
Standard and keyless.
Since the price is significantly different, from various suppliers.
And maybe the only advantage is of the Standard version, is frequency swap.
If so, then not so important. If the daily bread is 315 or 868.
And just very seldom, there is a import from abroad.
These facts, needs to be sorted out.
Weasel3 (12th August, 2022)
Please report here if any have made frequency change on the Audi BCM2 boards - 754j
If it is the key program generate menu.
It does not work, to swap from 434Mhz to 868Mhz.
Just get the error message. "Use keyless version key" or something like that.
Maybe need an update, to fix this.
Have a car waiting, so hope it is fixed soon.
Freq swap is not only sw, need replace some part on pcb to make 868 from 434.
Any option to make remote for vectra C / Signum ?
There is one option for vectra C , but people say - need to re sync after some time ?
Good afternoon
I'm trying to make a smartkey for a toyota NOAH 2011.
I made all the DST40 models, it accepts to program a beep, success, but it does not start the car.
Using all models the DST80 does not accept programming, does not activate or beep.
Has any friend had this problem?
Emulador ID 4D+DST40 start on car!
Upa-S ,Vvdi key tool, Zedfull, Xpad, KM100, Obdmap, Scanmatik pro2, Ioterminal, Pcmflash, Mdflasher, Fvdi, Ck100, Fvdi, Roudrill
Goodnight
I managed to get it working using vvdi smartkey xm28.
Ask/fsk change. power signal
Hi all ..
was thinking to buy xhorse universal remotes mainly for hyundai cars like
i30 2009
i40 2013
honda and some toyota cars...
basically some remotes r hard to get for me..so diside to buy them once that can be generated.
what would i buy from them?
key tool max pro and some remotes?
and where i can find support list of vehicles they can be used on..
Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
First download Xhorse app on your device and look around. Everything you asked can be found in there.
Then you can decide if you need Key Tool MAX or Key Tool Mini or something else.
gttuning (26th November, 2022)
