Page 175 of 177 FirstFirst ... 75125165170171172173174175176177 LastLast
Results 2,611 to 2,625 of 2641
Thread: VVDI KEY TOOL
  1. #2611
    Dec 2012
    EU
    Quote Originally Posted by autoTkey View Post
    First download Xhorse app on your device and look around. Everything you asked can be found in there.
    Then you can decide if you need Key Tool MAX or Key Tool Mini or something else.
    Cool.
    Didn't know they have app.
    I'm not familiar with xhorse..
    Thanks..
    Sent from my SM-G965F using Tapatalk
    Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
  2. #2612
    Apr 2022
    Germany
    @ gtuning
    With app you can see some things, but not all.
    Some things are easier with the practice (test it on a real device/ car) as well in theory...
    I bought myself an Vvdi MINI Key Tool an I was surprised (positive) what it can do.
    If you are in cloning business then is the really cheap tool for that...
    You can also reset used smart keys based on pcf chips (audi, bmw...).
    When I compare it with description in app internet, I would say better than described...
    I don’t have the max key tool version, so I can not give you the feedback that you need...
  3. The Following User Says Thank You to wuza For This Useful Post:
    gttuning (27th November, 2022)
  4. #2613
    Dec 2012
    EU
    Quote Originally Posted by wuza View Post
    @ gtuning
    Thanks..
    I ordered Mini key tool and some remotes..
    This should do me..
  5. #2614
    auto techniek's Avatar
    Mar 2017
    I ve a issue with generate remote Daihatsu Sirion 2007 433 mhz ASK two butons. Non of them worked.
    Anyone tried something else or any suggestions.
    Or may be procedure iw wrong. When disconnect bat for 1 min then press unlock and lock nothing happened.
  6. #2615
    Dec 2012
    EU
    Anyone here dose garage remotes with mini key tool..
    I have door in garage that says PM1 on the control box..
    I checked the app but can't see PM1 manufacturer in the list..
    Can we somehow clone remotes if there is no way to generate a remote??.
  7. #2616
    Jan 2017
    Netherlands
    Have you tried scanning frequency and just clone it on a remote? Did it for a customer this week and just read all buttons and generated on a hyundai/kia remote (4 buttons available like on the door remote). Might not have exact functions on the right pictures of the remote but I think it will work just fine. Customer asked for it, so just tried and he hasn't called me since (asked to try right away and call in if not working). Most garage door systems don't have rolling codes so should not be too hard.
  8. The Following 2 Users Say Thank You to Matronix For This Useful Post:
    gttuning (17th January, 2023), Weasel3 (16th January, 2023)
  9. #2617
    Dec 2012
    EU
    Quote Originally Posted by Matronix View Post
    Did try clone but..didn't really had time to do it properly..
    Will give it a go again..once not busy ..
  10. #2618
    Jul 2018
    Default VVDI KEY TOOL
    My KEY TOOL can't connect by blutheuuth if anyone can help to change blutheeuth where is
    345665848_762321535524555_6561281603858093875_n.jpg344309900_270945032034875_7513388293152554288_n.jpg
  11. #2619
    Feb 2014
    it's the little blue PCB on the right.
  12. #2620
    ttzag's Avatar
    digital-kaos
    Quote Originally Posted by Anass GM View Post
    carefuly heat it then try
    Actions speak louder than words
  13. #2621
    Mar 2017
    solved
  14. #2622
    Nov 2016
    Hi, anybody know if audi q7 2013 key can be cloned? I tried rolling and it says it reads it, and burn the remote, but then it dont work.
    About the transponder, not pretty sure of the procedure, if you put the key im the coil says unclonable, so that will be?
  15. #2623
    Feb 2014
    The procedure would be to program a dealer key in the car memory. No duplicating is possible on these.
  16. #2624
    Nov 2016
    Ok, that can be done with the mini key tool and vcds or i do need any other tool? Any procedures available online? Thanks!!
    Ps there should be a way, they manage to steal this cars in 30 seconds!!
  17. #2625
    Feb 2014
    They don't clone the original key for the stealing. There are other ways. KeylessGo are the easiest and fastest to grab.
    Get a VVDI2 or AVDI or Autel-like tablet and follow the given instructions.
    The first skill a novice locksmith should acquire is how to use search engines:
    - for example write Q7 autel in Youtube and you will get 1:1 instructions how to make and add dealer key to the car:
    https://www.youtube.com/watch?v=gvrK911L1rE
    I'm not experienced with VCDS but Keydiy surely won't be of any help on this car. It can't clone and it can't generate this key. You need to get proper key from your keys supplier, then convert it to dealer mode (not aware if VCDS has such expert functions, but I'm guessing - no), then program it to the car.
