Vvdi. If i put on vvdi original chip told me need do it online. If i put the chip i clone from original with keyline machine on vvdi then told me can do offline with sniff and ufter 1 hour i clone again on china chip . And if i put this china chip to clone again with vvdi than no need sniff. They do it on 20 sec
Στάλθηκε από το F3311 μου χρησιμοποιώντας Tapatalk
the first situation with original key that it does only online and Keyline offline i can't explain it, after that when you try to copy china chip with KEY TOOL it has saved the calculation of that chip and it does not need again calculation this is the same procedure with all chips.
the ID48 offline cloning with version 2.2.2 it is very good they have improved it.
I have version 2.2.2 too EU version but dont give me possibility to go offline even for normal ID 48. Just say go with 48 96 authorisation wich I dont have still.
i have copied many normal ID48 chips with no problem.
nagib (24th February, 2018)
Sorry my english is not good.
I have a car. for example a vw golf 2011.
if i try clone original key with vvdi need do it online
if i try clone with keyline also need do it online.
for examle i choose to do it with keyline machine. if i take this chip now ( the chip i have make with key line) and try clone it with vvdi now i can do it offline.
Original chip and the key line clone chip start the same car but vvdi original cant do it of line but keyline chip can .
Do you have to use the Xhorse Id48 copy Transponders or can you use Standard Magic 1 & Magic 2
milehighlockdoc (31st January, 2019)
delete, double post
must be editable , and good quality
this is very poor chip, loosing data quick , no need to be even in use, many spare keys with that chip not detect by cluster , stop working randomly
where to find better id 48, any recomandation?
nagib (28th February, 2018)
