Page 84 of 177 FirstFirst ... 3474798081828384858687888994134 ... LastLast
Results 1,246 to 1,260 of 2641
Thread: VVDI KEY TOOL
  1. #1246
    kostas's Avatar
    Jan 2009
    macedonia is greek
    Quote Originally Posted by Garfieldus View Post
    What size pins hold the key blade in place on the xhorse remotes?
    Like kd900 it's the same
  2. The Following User Says Thank You to kostas For This Useful Post:
    Garfieldus (11th April, 2018)
  3. #1247
    castin's Avatar
    Oct 2015
    HI. For VVDI Key Tool need TPX3, TPX4, JMD chips or must use special XHORSE transponder?
  4. #1248
    Oct 2016
    Scotland
    Quote Originally Posted by castin View Post
    I've used TPX3 with the tool before and worked ok. Not sure about JMD chips however, i've never used any of these.
  5. The Following User Says Thank You to WRX 14 For This Useful Post:
    castin (10th April, 2018)
  6. #1249
    Sep 2013
    Friends As Spring Cames and the birds where singing
    How really works new vvdi key tool cloning id 48 chip package.Some kind people or can share their experience?spring came and the birds were singing
  7. #1250
    Hello
    How to combine vvdi2 and key tool? I have it connected both to the same computer for over half hour and nothing.
  8. #1251
    Oct 2016
    Scotland
    Quote Originally Posted by EMCE159 View Post
    Hello
    Need to open the VVDI2 software and click on the transponder programmer option.
    Then along top menu bar, click 'points system' and you will find an option to enter your key tool serial number and bind the two devices while both connected to the computer.
    This means any bonus points you earn in key tool will be transferred to the VVDI2, and have all points in one place.
  9. The Following User Says Thank You to WRX 14 For This Useful Post:
    EMCE159 (11th April, 2018)
  10. #1252
    Mar 2009
    Quote Originally Posted by holbi1 View Post
    I made a copy of 2003 Skoda Fabia id48 key yesterday. Took around 10 mins.
  11. The Following 3 Users Say Thank You to madaxe For This Useful Post:
    Fernandowap (11th April, 2018), holbi1 (11th April, 2018), nagib (11th April, 2018)
  12. #1253
    foxtec800's Avatar
    I have a vvdi keytool with NA version,, spoke to supplier as i needed Eu,they say cant be done, can anyone tell me how to get the version swapped to Eu please.
    Thanks Guys :-)
  13. #1254
    Quote Originally Posted by WRX 14 View Post
    Thanks for your help I found this manual how to combinate Keytool + VVDI2 to get Copy 48 96bit
    http://forum.xhorse.uk/viewtopic.php...3a36b2587d4055
    and is working good, if someone needs.
  14. The Following User Says Thank You to EMCE159 For This Useful Post:
    AndyCZ (12th April, 2018)
  15. #1255
    Mar 2018
    Ireland
    Quote Originally Posted by kostas View Post
    Unfortunately I don't know the size of the kd900 pins either.
    I want to buy them on aliexpress but not sure what diameter to get. I reckon they're 8mm long.
    Can anyone tell me the size please?
  16. #1256
    Oct 2016
    Scotland
    They're 1.5mm x 8mm mate
  17. The Following User Says Thank You to WRX 14 For This Useful Post:
    Garfieldus (12th April, 2018)
  18. #1257
    Mar 2018
    Ireland
    I can find 1.6mm, 1.7mm and 1.8mm but no 1.5mm.
    Where do you get yours?
  19. #1258
    Oct 2016
    Scotland
    Try searching M1.5 x 8mm. I had actually bought mine off ebay.
  20. The Following User Says Thank You to WRX 14 For This Useful Post:
  21. #1259
    Feb 2014
    VVDI couldn't finish the job with an old 2003 Porsche Cayenne ID46 - it decodes the chip and writes to Xhorse ID46 but car doesn't start (I guess it doesn't like the chip). On the screen it tells the user to put either Xhorse ID46 chip or TPX3(4) chip, but refuses to accept the TPX.
  22. #1260
    DK Veteran labusas's Avatar
    Nov 2010
    Can anyone tell me if id48 VOLVO cloning works with VVDI key tool? I tried with VVDI2 and can not get past first step of 8 to sniff out
